-   -   Undercabinet Surface Mounted Box for Disposal Plug (http://www.diychatroom.com/f18/undercabinet-surface-mounted-box-disposal-plug-88463/)
xd11 12-02-2010 11:09 PM
Replacing my disposal from a batch to a continuous. The new one has a plug the old one did not. So I plan to use the Romex line to a surface mounted outlet box in the cabinet. What kind of box is permitted? I have a white metal Wet Location Box, and a plastic Carlon box that the store rep said was fine. But it says wall or ceiling mount only, and because the cabinet back sits off the wall by an inch I thought screwing into the side of the cabinet was most stable.
Also, can I use one of the proper rated remote appliance switches plugged in the outlet (per above) to control the disposal, rather than putting a wall swtich?
LyonsElecSupply 12-02-2010 11:16 PM
I dont know about switches, but as far as the box will go, I would use a metal Handy Box with knock outs. Thats all you really need. Make sure you ground the box.
You dont need a wet location box there. Without a weatherproof in use cover, its kind of pointless.
xd11 12-03-2010 09:38 AM
Lyons,
Thanks. I had the Outdoor box in my basement for two years and the Carlon was only 69 cents so no big deal either way; I can use a metal handy box. Is the romex from the old disposer-direct connection ok or do I need to replace it with BX to go to the new outlet box?
DangerMouse 12-03-2010 09:48 AM
This may depend upon your location.
Where are you?
DM
xd11 12-03-2010 02:55 PM
NJ. Single Family Home.
LyonsElecSupply 12-04-2010 08:40 AM
NEC says no, but local code may require MC.
If you enter from the wall directly into the box, just use a romex connector and you should be fine.
