undercabinet puck lights
I'm building some built-in cabinets for my living room and I intend on installing puck lights underneath the shelves. I've been doing some research and at least two manufacturers want the wires spliced together using mechanical terminals. I'm guessing that since the fixture leads are quite small and probably stranded that the concern is making a solid connection. Crimp caps would be another option. That being said, as long as the voltage of the lights is compatible with that of the transformer, I don't see any issue with cutting off the terminals. As I said though, I'd probably shy away from twist-on wire nuts for making these connections.
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
