Undercabinet Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 01:32 PM   #1
Knows everything but that
Rewards Points: 150
Undercabinet outlets
Oh a recent DIY TV show I saw an installer put kitchen outlets hidden underneath the cabinets. Is this up to code in the US? It makes for a really clean back splash look. Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 06-05-2010, 03:06 PM   #2
Master Electrician
Rewards Points: 3,916
Yes it can be done with wiremold and GFCI circuit breakers. Much more costly however.
brric is online now   Reply With Quote
Old 06-05-2010, 06:25 PM   #3
Rewards Points: 150
Thanks. Its only money. What is wiremold?
Shane
Old 06-05-2010, 07:02 PM   #4
Master Electrician
The Following User Says Thank You to brric For This Useful Post:
JakAHearts (06-05-2010)
Old 06-05-2010, 08:41 PM   #5
Rewards Points: 150
Originally Posted by brric View Post
The show I saw had regular outlets encased in plastic boxes with regluar faceplates on them. The wiring was then encase in some sort of plastic also. Ever see anything like that?
Old 06-05-2010, 08:52 PM   #6
Rewards Points: 1,910
Hidden under the upper cabinets or the lower cabinets? I'm pretty sure lower cabinets is a no no. Little ones will pull appliances off the countertop by pulling on the cords.
Old 06-05-2010, 09:53 PM   #7
Just call me Andrew
Rewards Points: 1,020
I assume he means on the underside of upper cabinets.
Andrew
secutanudu is offline   Reply With Quote
Old 06-06-2010, 10:51 AM   #8
Licensed electrician
Rewards Points: 1,750
Check out page 798 of this link.
http://www.hubbell-wiring.com/htm/ResiSwitches.htm
As long as the receptacles are no higher than 20" above the countertop it will satisfy the code.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
