Undercabinet Lighting On Small Appliance Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 10:56 AM   #1
Undercabinet Lighting on Small Appliance Circuit
Is it against code to tie off of one of the small appliance circuits, through a switch to the undercabinet lighting?
behrend is offline   Reply With Quote
Old 08-05-2010, 11:01 AM   #2
Yes, no hard wired lighting can be tied in
A transformer for lights could be plugged in
Or a table lamp plugged in
Old 08-05-2010, 12:35 PM   #3
Electrician
Proby's Avatar
Yes, it is against code. Is it a safety hazard? Not at all. This is simply an issue of the NEC sticking it's nose into design issues, something it should have no part of.
Be aware that if you were to do this, you would have to run #12 wire to the UC light. That could be a bit tricky when feeding 120V lights directly. It's better to just use another 15A circuit with #14 wire.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 12:39 AM   #4
Electrical Contractor
kbsparky's Avatar
You can install a wall switch for control of undercabinet lights and have the installation be code-compliant on your SA circuit.
This back-door method involves installing an outlet under the cabinet, usually in a shallow wire-mold box. Your wall switch can control this outlet. Simply plug in your fixture into that outlet.
As long as it's cord-and-plug connected, the Code is satisfied.
-KB
New circuit breaker owen22 Electrical 14 01-12-2010 08:08 PM
20 amp lighting circuit trosenda Electrical 4 01-04-2010 01:26 PM
Best undercabinet lighting ingeborgdot Electrical 5 10-06-2009 12:00 AM
Do I need a new box? pcampbell Electrical 20 01-07-2009 07:16 PM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 11:38 AM
