-   -   Undercabinet Lighting on Small Appliance Circuit (http://www.diychatroom.com/f18/undercabinet-lighting-small-appliance-circuit-77977/)
behrend 08-05-2010 09:56 AM
Is it against code to tie off of one of the small appliance circuits, through a switch to the undercabinet lighting?
Scuba_Dave 08-05-2010 10:01 AM
Yes, no hard wired lighting can be tied in
A transformer for lights could be plugged in
Or a table lamp plugged in
Proby 08-05-2010 11:35 AM
Yes, it is against code. Is it a safety hazard? Not at all. This is simply an issue of the NEC sticking it's nose into design issues, something it should have no part of.
Be aware that if you were to do this, you would have to run #12 wire to the UC light. That could be a bit tricky when feeding 120V lights directly. It's better to just use another 15A circuit with #14 wire.
kbsparky 08-05-2010 11:39 PM
You can install a wall switch for control of undercabinet lights and have the installation be code-compliant on your SA circuit.
This back-door method involves installing an outlet under the cabinet, usually in a shallow wire-mold box. Your wall switch can control this outlet. Simply plug in your fixture into that outlet.
As long as it's cord-and-plug connected, the Code is satisfied.
