-   -   Undercabinet lighting power source? Ideas? (http://www.diychatroom.com/f18/undercabinet-lighting-power-source-ideas-36752/)
PDubs 01-24-2009 08:12 PM
We're doing a kitchen remodel and I currently have the drywall out exposing the outlets for the countertops. I want to install undercabinet lighting but after scanning many sites, there was mention that I could not use the last outlet in a (dedicated) circuit to be my power source. Is that right? The circuit has a GFCI on it and it is a circuit just for the outlets on the countertops only. Here are some other details for the kitchen area:
- Sink is located on a kitchen island, so there is no water source near the cabinets/counters where I'm trying to install the lights.
- I was planning to use the last outlet as a power source and put the junction box exposed in the bottom cabinet somewhere.
- Circuit I was planning to use is on a standard 20A'er.
I was trying to do this work myself since I have some basic electric skills, but if I need to hire a professional, so be it. Anyone else hook these up? I'm looking to chain about 5 together on a switch but not do it where I have to physically plug them in to an outlet. I would rather have them wired in directly and put on a switch.
swaterbenny 01-24-2009 08:32 PM
Maybe just mount a receptacle in the back of a cabinet, and run the plug in up to that? You could have it switched by making it a switched outlet. Just a thought I'm having trouble seeing what your talking about though....
As for the not using the last receptacle... I don't think you would be allowed to use any receptacle because those 2 20 amp circuits are dedicated for kitchen appliances? Good luck Ben
dSilanskas 01-24-2009 09:38 PM
Kill the power to the last outlet you plan on using, Remove the outlet and the box that the outlet is installed in. Change the box to a two gang box. Poke a little hole above the outlet I am assuming that is where you want to start the lights. Fish a wire down to the two gang box. You can hard wire the lights into the whip you left. After you are done wiring the lights install the outlet and put a switch in.
Bob Mariani 01-25-2009 06:33 AM
The outlets in a kitchen cannot be used for lighting by code.
Ultrarunner2017 01-25-2009 08:31 AM
Why not just run another 15A, 14/2 cable for the lighting? As has already been said, you cannot use a dedicated kitchen receptacle circuit for lighting. Besides, 14/2 will be much easier to work with than 12/2.
FW
chris75 01-25-2009 08:35 AM
FW
Oh sure, confuse the guy with simplicity.... :laughing:
PDubs 01-27-2009 11:01 PM
FW
So uh...yeah. Did you want to supersize that? :)
Seriously, that totally went over my head. :eek: It sounds like you are saying create a new 15A circuit from the breaker box, but the fractions following that sound like wire gauges? When I pulled the wall apart, I can see the beige-colored wire wrap with what looks to be 3, 12 gauge copper wires. Not sure if that's accurate or not, but the house was built in 1999.
If I'm understanding you right, and from Googling "14/2", it sounds like I should run a new 15A circuit breaker line using 14/2 cable? If that's true, then how in the heck do I access the back of the breaker box and shut off MAIN power to add a new line/circuit? I know I have a secondary fuse box outside of the house but didn't check to see if it has MAIN switch on there or not.
Bob Mariani 01-28-2009 04:37 AM
These lights do not take much power. Either take power from a light switch box or from a junction box in the attic or basement. Just not from the kitchen or dinning room receptacle outlets.
