Under-rated Service Drop? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 08:37 AM   #1
Under-rated service drop?
Hi;
About 10 years ago, we put an addition on our home, and the electrical panel was replaced. The service was upgraded from 100A (220V) to 200A.
The service cable was changed, but not the utility's drop from the pole.
The service wire is obviously much larger than the wire from the pole.
Compared to my neighbor's service, our wire (from the pole to the house) is definitely a lot smaller.
I'm wondering why the utility did not replace their wire when the service was upgraded.
FW
fw2007 is offline   Reply With Quote
Old 07-08-2008, 09:17 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
They follow much different rules about wire then we do in a house.
Most of the time, they will not upgrade unless you have an old 60 amp service.
Old 07-08-2008, 09:51 AM   #3
I guess if we were really drawing close to our 200Amp capacity, we might notice a larger voltage drop, and perhaps convince the utility to upgrade the drop. Currently, we aren't even close to that.
FW
Old 07-08-2008, 10:54 AM   #4
Rewards Points: 78
Originally Posted by fw2007 View Post
Hi;
FW
Because they can do anything they want! Remember your wires are overhead in free air not in conduit.
I have two poles. One on the road with a transformer on it and another pole in my yard. The wires between the two poles were not touched, but the under ground lateral was increased in size. I think they used 4/0 AL.
Old 07-08-2008, 01:36 PM   #5
Power Gen/RS Engineer
Rewards Points: 566
We have a winner! Just look at the tables in the NEC (well, I don't expect you, the OP to; Only nerds like me concern themselves with goofiness like this!) and note the difference in allowable ampacity between the same conductor number/size in raceway vs. free air. You can get a much higher rating for a service drop. Now the service point, i.e. where the service conductors are tapped to the drop, represents the demarcation point between the homeowner and utility. At this point, we all have to play by the NEC rules. Also as J.V. mentioned, they (POCo) can do pretty much what they want and that being said, they will size the conductors according to an anticipated maximum load, regardless of what size panel you have (their numbers come from years of experience).
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-08-2008, 08:24 PM   #6
I guess that's how they (the utility) get away with the ancient wiring on the street.
We still have the separate 3-wire system, not the twisted set used today.
The transformer is also very ancient. I'm hoping that the day it decides to pop, my car won't be sitting out on the street, 1/2 pole away.
I had a dream the other night that it (the transformer) exploded. I hope it's not a premonition<g>. Wonder what kind of answer I would get from the PC if I told them I thought the transformer should be replaced... NOW! because I dreamed that it was going to explode...
One did explode on the block behind our house, but I wasn't there to witness it.
FW
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
New Service Drop derby1251 Electrical 5 05-07-2008 08:20 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
