Under-deck Patio Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 04:26 PM   #1
Rewards Points: 117
Under-deck patio lighting
Hi All,
I currently have a raised deck above a stamped concrete patio. In the near future I am going to waterproof the underside of the deck using EPDM as shown in the attached diagram .
I would like to add some lights (low-profile would be best) to the ceiling once it is dried in, but because of the membrane there is very little room for wiring, cans etc. Does anyone have any suggestions as the best way to approach this? This is already an exterior light wired to an interior switch by the door that leads out to the patio if that is going to help.
Regards
Chris
spiragui is offline   Reply With Quote
Old 06-29-2011, 04:54 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would do something with low voltage and surface mounted fixtures. The low voltage wire could be run above the ceiling and below the membrane and no electrical boxes would be needed.
Coastal South Carolina
Old 06-29-2011, 06:50 PM   #3
Too Short? Cut it Again!
Take a look at some marine catalogs. They will have some nice lighting alternatives for boat decking, docks and so forth that should be adaptable.
Old 07-06-2011, 09:37 AM   #4
Rewards Points: 117
A belated thanks for the replies. I think I will probably look at regular outdoor lighting, purely due to the costs involved with the LV.
Cheers
Chris
Old 07-06-2011, 01:25 PM   #5
Rewards Points: 1,552
I'm curious as to how you drain the water that goes through the top deck boards and will eventually rest on top of the EDPM membrane?
bob22 is offline   Reply With Quote
Old 07-06-2011, 04:29 PM   #6
Rewards Points: 117
Hi Bob,
At the ledger board the EPDM membrane will be flat, the droop shown in the image will gradually increase as you get further from the house. Each panel between the joists is kinda fan-shaped to create this gradual droopiness.
This should give me a gradient of about 1/8" per foot of distance from the ledger board, but this could be increased by increasing the height of the compression strips (trading-off headroom, but I'm no basketball player so it wouldn't be distastrous), if anyone thinks that this is insufficient gradient.
Cheers
Chris
Old 07-06-2011, 05:28 PM   #7
I assume the floor joists run perpendicular to the house?
Old 07-06-2011, 05:38 PM   #8
Rewards Points: 117
That they do.
Cheers
Chris
Old 07-06-2011, 05:49 PM   #9
A "Handy Husband"
rjniles's Avatar
Cheers
Chris
Actually LV lighting is pretty cheap.
Tags
deck , lighting , outdoor
Ideas for deck over concrete patio and beyond-pics- bdobs General DIY Discussions 11 10-22-2010 09:50 AM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 07:57 PM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
Ideas for deck over concrete patio and beyond-pics- bdobs Building & Construction 6 05-10-2009 09:58 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
