Under Cabnet Lighting Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 05:14 PM   #1
master of no trades
The Barber's Avatar
under cabnet lighting not working
I installed under cabnet lighting about 6 months ago. Now one of them is not working. I feel it is too soon for the bulb to go out. (floresent) My question is do you think the bulb went out or is it something else before i start buying new things try and repair them.
The Barber is offline   Reply With Quote
Old 07-08-2008, 05:17 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Just take the bulb out of one of the other lights and test it. If it comes on, it's the bulb.
wirenut1110 is offline   Reply With Quote
Old 07-09-2008, 03:20 PM   #3
master of no trades
The Barber's Avatar
that would be nice if it were that simple. It just so happens it is the only one that does not match the others.
Old 07-09-2008, 03:31 PM   #4
Just buy a new bulb. They're cheap, and you can always use it later if the problem turns out not to be the bulb.
On the other hand...
If the fixture uses electronic start (which most do), then you could have a fried starter circuit. That would mean you have to replace the whole fixture.
Unfortunately, the electronic start is a lot more susceptible to surges/spikes. It took a lot to knock out the old starter and ballast in the older models, but today, all you need is one good lightning storm.
Did this lamp stop working after a storm?
If it were I, I would buy the new bulb first, and go from there.
FW
fw2007 is offline   Reply With Quote
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
