Old 12-16-2012, 11:09 AM   #1
Under cabinet lights cutting out
Our house has lights mounted under the kitchen cabinets. They worked fine for a couple years, but now are cutting out after just a few minutes of operation. After an hour, they might come back on for a few minutes, but cut out again.
I suspect that the power transformers are failing, but I don't know. There are two transformers, and the lights connected to the second transformer don't have this problem.
These appear to have been installed by an electrician, they're cleanly wired to an electrical box above the top cabinets, and they're controlled by a wall switch.
Should I replace the whole system with better tech (LED?)? Replace the transformers? Are the transformers easy to source? Affordable?
Thanks.
DWooderson is offline   Reply With Quote
Old 12-16-2012, 11:33 AM   #2
Semi-Pro Electro-Geek
What is the total load on the transformer? If it's more than about 40W, you should probably replace it with a bigger transformer - you don't want it operating close to its max ratings. Lighting transformers are cheap, like under $10. Check Amazon. An LED replacement would cost more, but use less power and require no maintenance. Might be worth it.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Recommendations for Dimmable Under Cabinet lights drex Electrical 4 04-23-2012 10:25 AM
Want to make under cabinet lights right Dshow Electrical 3 06-23-2011 08:49 PM
Cutting cabinet doors Breakthecycle2 Carpentry 11 05-19-2011 10:01 PM
Under cabinet Lights? kcrossley2 Electrical 44 06-27-2010 12:14 PM
under cabinet lights Barry J Electrical 3 07-05-2009 11:07 AM
