Under Cabinet Lights? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 07:43 PM   #31
Rewards Points: 552
No, it a 15 amp circuit.
kcrossley2 is offline   Reply With Quote
Old 06-11-2010, 09:34 PM   #32
Rewards Points: 552
Okay, I have another problem. I received my Kichler under cabinet lighting system today, but I forgot to order (3) of these, which I need to form a T to branch off two runs of 10 gauge low-voltage wiring:
Is there anyway I can use these instead with spade terminals? It's all I could find locally. The only problem is the terminal strips leave the 12 volt low-voltage wiring exposed.
I'll also need to jumper a few of the terminals with a piece of 14/2 wire as well. Man I hate it when I forget stuff. Of course, I could just order the funky Kichler T and be done with it. What do you think?
Old 06-11-2010, 10:18 PM   #33
You are using 10g for low voltage ?
Thats a heavier guage then #12
Old 06-11-2010, 10:26 PM   #34
Master Electrician
Rewards Points: 3,676
Why can't you just use wire nuts?
brric is online now   Reply With Quote
Old 06-11-2010, 10:30 PM   #35
Rewards Points: 552
Yeah, I was surprised by that too. Pretty thick for LV.
Old 06-11-2010, 10:31 PM   #36
Rewards Points: 552
Have you ever seen a wire nut that's big enough to tie together (3) 10-gauge wires? They're HUGE!
Old 06-11-2010, 10:42 PM   #37
10A in #10 copper @ 12v gives a 5% drop with 30' of two conductor cable.
Your lamps will last longer if you go to thinner wire.
Old 06-11-2010, 10:45 PM   #38
Rewards Points: 552
I can't. The Kichler cable fits into the Kitcher tracks, which supports the Kichler sockets. My run length is only 27'. BTW, I'm only using (12) 10 watt bulbs. According to Kichler's calculations the voltage drop between the first bulb and the last is only .5088 volts, but that's assuming a straight run. My setup will include (3) T's. Not sure how that affects all of this.
Old 06-11-2010, 11:55 PM   #39
Rewards Points: 552
Okay, here's what I was thinking about doing. There would be three of these. One set of wires in, two sets out. Each terminal would be hidden from sight, but the wiring would be exposed. Am I breaking any electrical codes with this possible setup?
Old 06-12-2010, 12:28 AM   #40
Rewards Points: 552
BTW, I just noticed that all of the outlets on my counter appliance circuit are 15 amps, even though the circuit has a 20 amp breaker and 12/2 yellow sheathed wiring. Is that allowed?
Old 06-12-2010, 01:03 AM   #41
yes it is
fpeftw is offline   Reply With Quote
Old 06-12-2010, 01:16 PM   #42
Rewards Points: 552
I just found out that I need to order some under cabinet trim to hide the linear lights, which are about 1/8" too high. Since I have to wait for that to come in I decided to order the funky Kichler connectors and do it right.
Old 06-12-2010, 01:29 PM   #43
11.5 v gives you 13% less intensity and twice the operating hours.
Old 06-26-2010, 08:12 AM   #44
Rewards Points: 552
Hey guys, I need some more help. The Kichler linear lighting I'm installing is 1/8-1/4" too high for the cabinet frame recess, which means I had to purchase some Merrilat trim to install under the cabinets. I plan on using a nail gun to attach the trim, which is about 1/2" thick. The cabinet frame to which the trim attaches is 1.5" thick.
Should I use finishing nails or brads to attach the trim?
Old 06-27-2010, 12:14 PM   #45
Rewards Points: 552
Hello everyone. I've run into a snag as indicated above. I'm pretty sure screws are out of the question because I'll need to make sure the trim is tight to avoid light seepage. If you know anything about kitchen cabinet carpentry, please help me with this new thread I created to help solve this problem: http://www.diychatroom.com/f14/insta...76/#post461928
Thanks,
Kelly
how to wire under cabinet lights sjahan22 Electrical 13 02-15-2010 10:55 AM
Under cabinet lights dismas Electrical 3 01-15-2010 04:52 PM
under cabinet lights 7echo Electrical 3 12-06-2009 08:24 AM
under cabinet lights Barry J Electrical 3 07-05-2009 11:07 AM
German Bathroom Cabinet with Lights jhassall@dornbracht.co.uk Electrical 2 01-06-2009 01:58 PM
