Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 12:35 PM   #1
Rewards Points: 16
Under cabinet lights
I used to have some under cabinet fluorescent lights. Since I hate fluorescent lights, I was glad when they died. One of those lights was under the cabinets on the left of the attached pic. The power comes directly out of the wall and is controlled by the switch on the left. This can be seen in the other pic.
So, I installed a few new lights from a kit. They're under the cabinets on the left of the included pic. My wife liked them so much that we got another two sets. We want to put one set over the stove. What I'm wondering is if I can just drill a hole through the bottom of the cabinet and run the wires through the cabinets. This would keep the wires hidden, especially where they would have to run down the outside of the cabinet to the upper left of the stove. The reason why I'm wondering this is because if we try to sell the house at some point, will we have problems because these wires are running through the cabinets?
The lights are each rated for 120V.
dismas is offline   Reply With Quote
Old 01-15-2010, 01:10 PM   #2
I can offer a couple of suggestions that may be worth considering. I have seen enough "professional" installation of wires in cabinets to assume that this practice must be acceptable. However, all such examples I have seen have the wires in conduit (rigid or flexible), to protect from inadvertant damage and shock. Second, make sure you put all connections (wire nuts in lower photo) in junction box. Exposed connections such at the ones you have are not good.
As a personal view, I think this also happens to look better, and as if the installer knew what they were doing.
oberkc is offline   Reply With Quote
Old 01-15-2010, 02:41 PM   #3
Rewards Points: 16
What options do I have for a junction box for this? Do they make one that just tucks up under there?
Old 01-15-2010, 03:52 PM   #4
I have a situation very similar to yours. I found a thin junction box at one of the usual outlets. It is about 1" thick. If I recall, they are pretty commonly available. I mounted the switch in mine, as well as the wire connections.
under cabinet lights 7echo Electrical 3 12-06-2009 07:24 AM
under cabinet lights Barry J Electrical 3 07-05-2009 10:07 AM
Under cabinet lights Cossack Electrical 4 04-02-2009 08:41 PM
German Bathroom Cabinet with Lights jhassall@dornbracht.co.uk Electrical 2 01-06-2009 12:58 PM
kitchen under cabinet lights DIYGST Electrical 1 01-05-2009 01:01 PM
