Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 10:45 AM   #1
Rewards Points: 222
under cabinet lights
when wiring. can/should they be hard wired in a box, or should i put an outlet and plug em in ? this will be in the back wall inside the cabinets. and they will all be on a wall switch. 120v.
Fix'n it is offline   Reply With Quote
Old 09-02-2013, 10:46 AM   #2
Rewards Points: 222
oh. while we are at it. any tips and/or advice on anything to do with under cab lights ?
thanx
Old 09-02-2013, 10:51 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Technically, you cannot run a cord from the UC lights thru the cabinet to a receptacle.
The right way to do this is to run a whip out just under the cabinets and hardwire the fixtures.
You could also install a receptacle outside of the cabinet and plug them in. However, I have had a couple inspectors make customers hard wire them.
Old 09-02-2013, 10:59 AM   #4
Rewards Points: 222
yeah, thats what i thought. even though i did it in last home.
so. your saying that there would be wire nuts under my cabinets ?
i don't like that option. more stuff on the backsplash.
Old 09-02-2013, 11:01 AM   #5
k_buz's Avatar
No, all connections to the fixtures would be made inside the fixture. I can assume you purchased fixtures with cords already on them...
Those do not lend themselves well to hardwiring. You really need to find fixtures that are specifically designed for hardwiring.
Old 09-02-2013, 11:10 AM   #6
Rewards Points: 222
i have not purchased the UC lights yet. that is a winter project.
is running NM through drywall code ?
Old 09-02-2013, 11:12 AM   #7
Rewards Points: 222
is there a flat'ish box i could mount to the underside of the cabinet ?
Old 09-02-2013, 11:15 AM   #8
k_buz's Avatar
Ummm...yeah. The fixtures would/should be tight to the wall. There will be no exposed romex. Although, exposed romex on the bottom of an upper cabinet would probably pass code.
Nothing THAT flat.
Old 09-02-2013, 11:31 AM   #9
Rewards Points: 222
Nothing THAT flat.
really ? i installed my last ones at the front underedge of the cabinet. it worked real well lighting the countertops. i plan to do the same here.
perhaps i can modify a plastic, or even metal, box to make it real flat. it would only need to hold a lil wire and 3 nuts. hmmmm
Old 09-02-2013, 11:36 AM   #10
k_buz's Avatar
Undercabinet lights should be at the back of the cabinet...at least the hardwired ones I have used.
You can not modify a box. You could cut it into the bottom of the cabinet (facing down) but that is a hell of alot more work than hardwiring the fixture.
You would need a box at least 10 CU IN.
Old 09-02-2013, 11:44 AM   #11
Rewards Points: 222
ok. do you know how deep the shallowest box is ?
Old 09-02-2013, 11:44 AM   #12
Rewards Points: 222
btw, THANX for your advice.
Old 09-02-2013, 02:32 PM   #13
Rewards Points: 141
Do you mean under cabinet puck lights? .... using a 12V transformer and 20W (or so) halogen or LED bulbs? Check out the selection at a big box store ... hardwired with a wall switch is the way to go.
RocketGal is offline   Reply With Quote
Old 09-02-2013, 08:09 PM   #14
Rewards Points: 222
idk what i am going to get, yet.
Old 09-04-2013, 06:44 AM   #15
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
they make a wire mold box that is 3/4" , blank it off ....we use that as the junction at each set of cabinets ... usually like 3 different sets .. then you can use NON NM under the cabinet .... the 120v puck light kits are inexpensive, we cut the cords/plugs off and then use the junction ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Fix'n it (09-04-2013)
Help with replacing under cabinet lights miami mama Electrical 4 10-20-2011 11:03 PM
Want to make under cabinet lights right Dshow Electrical 3 06-23-2011 08:49 PM
Under cabinet Lights? kcrossley2 Electrical 44 06-27-2010 12:14 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
under cabinet lights Barry J Electrical 3 07-05-2009 11:07 AM
