Under Cabinet Lighting Direct Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 06:53 PM   #1
Under cabinet lighting direct wiring
I am remodeling my kitchen and I want to hardwire in under cabinet lighting. I want to locate the fixtures at the front edge of the cabinet and run the romex back along the underside of the upper cabinet and into the wall, up to a j-box in the attic (where it will meet up with the wires from the other lights) and over to a switch. I'm told that it doesn't meet code to have exposed romex like that, even the 8 inches or so on the underside of the cabinet. Can I just cover this with wire mold or is there some other perferable way to make this connection?
Schwarzaroo is offline   Reply With Quote
Old 12-29-2008, 07:45 PM   #2
Rewards Points: 2,350
Romex can be exposed where it is not subject to excessive moisture or physical damage. For your use I would consider it acceptable.
Old 12-30-2008, 04:26 PM   #3
wiremold works good or you can get kichler undercabs that have interconnect cords. You can daisy chain the lights together. I like the kichlers because you dont need to do and wiring beside the first light.
cambruzzi is offline   Reply With Quote
Old 12-30-2008, 07:05 PM   #4
Electrician
exposed NM (RX) is fine and legal.
chris75 is offline   Reply With Quote
Old 12-30-2008, 07:31 PM   #5
Rewards Points: 150
Not to hijack but since it's on same topic no need to start new thread. I have a manufactured home with no access to attic and such. Can you tap into an outlet on the backsplash to gain power for a switch/undermount light?
MikeVila is offline   Reply With Quote
Old 12-30-2008, 10:25 PM   #6
Licensed electrician
Rewards Points: 996
Sorry Mike,
The small appliance branch circuits for the countertops cannot serve lighting loads.
Under Cabinet Lighting alexgwoodruff Electrical 1 07-09-2008 09:15 PM
Low Voltage Cabinet Lighting Recommendations BigJimmy Electrical 2 01-20-2008 02:01 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
