Under Cabinet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 11:59 PM   #1
under cabinet lighting
Just wondering what is the best way to run under cabinet lighting. I do not want the plug in from the first bank of lights comming down the wall and plugged into my counter plug. I already have the wire to a switch just not sure what to do now. How do i hardwire these? My cabinets will have the wood trip around the bottom to hide wiring and the lights. Again im in Canada , Alberta .
Thanks all you guys are really great on this site.
83trekker is offline   Reply With Quote
Old 01-10-2010, 08:21 AM   #2
Remodeling Contractor
Run the wire from the switch to a junction box in the back of one upper cabinet. Route the undercabinet light wires along the back bottom of the cabinets and then into the junction box.
Old 01-10-2010, 10:25 AM   #3
Rewards Points: 1,016
In my recent kitchen remodel I installed a switched 120v outlet in the cabinet above the cooking range, above the exhaust hood. There I plug in a low voltage transformer and ran the wires down and around the underside of the cabinets to the lights.
One issue I encountered was that I selected halogen low voltage round puck lights - they run very hot - so hot as to be uncomfortably warm to the touch inside the cabinet. I placed a 6"x6" piece of sheet metal as a heat shield between the light and the cabinet - problem solved. If I had a do-over I would use LED lights.
Old 01-10-2010, 11:39 AM   #4
All the under mount lights i see have a normal plug in, would i cut that off and run it into the box and hard wire it?
Old 01-10-2010, 02:18 PM   #5
yes if these are line voltage lights (120V) No if these are low voltage and have a prong end to connect to a transformer.
Old 01-10-2010, 10:05 PM   #6
Can i install a plug in the cuboard like i do for a built in microwave oven?
Old 01-10-2010, 10:51 PM   #7
Unhappy
I will not say that Halogen lights (in a kitchen) are "Pasee". But they are not the rage they once were. Today. LED lights are in vogue. For the very reason that you describe. I personally was very hesitant to design and install Halogen lights in kitchens. (even the low voltage lights.)!
Last edited by spark plug; 01-11-2010 at 12:42 PM. Reason: misspelling (Pasee vs. Passee)
spark plug is offline   Reply With Quote
Old 01-11-2010, 08:08 AM   #8
yes that is what you would do.
Before I close walls: hard wiring under cabinet lighting with Romex. jws3 Electrical 6 08-29-2009 01:24 PM
Under cabinet lighting direct wiring Schwarzaroo Electrical 5 12-30-2008 10:25 PM
Under Cabinet Lighting alexgwoodruff Electrical 1 07-09-2008 09:15 PM
