Unbridged Wall Outlet? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 09:12 PM   #16
Electrical Enthusiast
Rewards Points: 504
Originally Posted by jbfan
They have the same meaning!
It must have either a switched receptacle or switched lighting outlet.
Oh I see I was using receptacle and lighting outlet interchangeably....
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
jbfan (03-26-2013)
Old 03-26-2013, 10:15 PM   #17
joed's Avatar
Rewards Points: 13,722
If you want it to be the same as what you have now just be quality normal receptacles and cut the tab to match what is there now. There are no special receptacle fro split wired receptacles. You just buy normal ones and cut the tab.
Old 03-26-2013, 10:18 PM   #18
BillZ's Avatar
Went ahead and did it tonight when I got off work. Worked out perfectly. Thanks for all the help.
BillZ is offline   Reply With Quote
Outlet box outside of wall? tommy83 Electrical 1 11-28-2012 12:06 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 08:16 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
