Unbridged Wall Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 07:27 AM   #1
BillZ's Avatar
Unbridged wall outlet?
New to me house. Switched receptacle. Only one of the outlets is affected by switch, other is always on. Is this a special receptacle? Is there a way to take the bridge out? Home center item?
BillZ is offline   Reply With Quote
Old 03-26-2013, 07:35 AM   #2
Rewards Points: 2,516
Nothing special. Has to do with the tab on the side of the receptacle
Have no idea what you mean by taking the bridge out?
Either you want both halves of the receptacle to be switched or you want both halves to be always HOT
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
BillZ (03-26-2013)
Old 03-26-2013, 07:38 AM   #3
BillZ's Avatar
Is this a modification the original installer made? Several like this in house. Haven't pulled cover yet. Weekend project changing out worn plug,......and outlet colors for wife.
Old 03-26-2013, 07:40 AM   #4
BillZ's Avatar
Didn't know how to describe how both got power or how to separate. Thought copper tab was a sort of a bridge.
Old 03-26-2013, 07:47 AM   #5
Rewards Points: 14,312
It s a jumper, just use a pair of needle nosed plyers to snap it off.
BillZ (03-26-2013)
Old 03-26-2013, 07:55 AM   #6
BillZ's Avatar
Thanks. Kind of my thought but I've had really bad ideas in the past.
Old 03-26-2013, 08:20 AM   #7
joed's Avatar
Rewards Points: 13,752
Only the tab on the hot(gold) side gets broke off. Take a close look at the old receptacle when you remove it before you break the tabs. Make the new one match the old one.
The Following User Says Thank You to joed For This Useful Post:
BillZ (03-26-2013)
Old 03-26-2013, 08:35 AM   #8
So do you want the new receptacles to function the same as the old? where one half is switched and the other half is always HOT?
Old 03-26-2013, 09:11 AM   #9
BillZ's Avatar
Yes. One has a lamp, other has a phone base.
Old 03-26-2013, 05:50 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,610
If only one is switched whilst the other is not !
Then the bridge is most likely already out !
What do you want, both switched ?
Or both pemanent powered ?
dmxtothemax is offline   Reply With Quote
Old 03-26-2013, 08:17 PM   #11
BillZ's Avatar
I'm replacing it. Wasn't sure if I needed to buy a particular outlet or modify. Think I'm squared away now.
Old 03-26-2013, 08:23 PM   #12
Rewards Points: 1,192
Code says every room must have a switched lighting outlet.
bobelectric is offline   Reply With Quote
Old 03-26-2013, 08:26 PM   #13
BillZ's Avatar
All the rooms have overheads besides this one. This one will remain switched.
Old 03-26-2013, 08:30 PM   #14
Electrical Enthusiast
Rewards Points: 504
I thought this was only if there is no overhead light?
Kyle_in_rure is offline   Reply With Quote
Old 03-26-2013, 08:59 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
They have the same meaning!
It must have either a switched receptacle or switched lighting outlet.
The Following User Says Thank You to jbfan For This Useful Post:
Kyle_in_rure (03-26-2013)
Outlet box outside of wall? tommy83 Electrical 1 11-28-2012 12:06 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 08:16 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
