Unbalanced Power - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 03:53 PM   #1
unbalanced power
i would like to know that if i have a steady load on one side of my 200 amp service panel of 20 amps or higher if my electric meter would read this imbalance as a higher draw than having it more evenly distributed
johnny31 is offline   Reply With Quote
Old 10-27-2008, 04:33 PM   #2
Rewards Points: 2,350
No, more load on one side or the other will not cause your power bill to reflect it. A kilowatt-hour is still a kilowatt-hour, no matter which leg of the service it is on.
Old 10-27-2008, 07:10 PM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
Just as InPhase277 said, a kWh is a kWh, doesn't matter how that electrical energy is used or how it gets there, you are paying for it.
If your entire house is running off one leg of the panel (highly unlikely) you would have issues with tripping the main breaker if you exceed the current rating of the main on one leg. It's always good to have the power balanced and as even as possible.
theatretch85 is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
