Unable To Install Ground Rod - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 10:31 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The Following User Says Thank You to stickboy1375 For This Useful Post:
Ultrarunner2017 (03-18-2013)
Old 03-18-2013, 10:32 PM   #17
Licensed electrician
Rewards Points: 1,054
Only the connection from the first rod to the panel needs to be continuous.
Use a 2nd acorn on the first rod and a jumper conductor to the second rod.
Old 03-18-2013, 11:03 PM   #18
Rewards Points: 820
OK. That makes sense.
Thanks.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-18-2013, 11:05 PM   #19
Rewards Points: 820
Originally Posted by stickboy1375 View Post
A picture is worth 1,000 words!
Thanks.
FW
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
