Unable To Drive Grounding Rod All The Way In - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 01:03 AM   #1
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Unable to drive grounding rod all the way in
I was able to get all but about 10 inches of a grounding rod in so I dug as much of a trench as I could next to it and bent it over so nobody would trip on it. Is it possible that I could just fill in over the rod because we plan on filling this area with more fill after inspection. I have never ran into this issue and I am kinda stuck here. Any help would be greatly appreciated.
rrolleston is offline   Reply With Quote
Old 01-12-2012, 01:23 AM   #2
Julius793's Avatar
Well I don't know if the inspector will like it but I do know some electricians will just take a grinder and cut it. I don't suggest it because its not legal however if you do it, take a sledge hammer and bang the top up so if the inspector feels the top it won't be nice and smooth.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-12-2012, 01:41 AM   #3
rrolleston's Avatar
Yeah sometimes they check the rods for the imprinted part at the top. If bending it over is not acceptable I will just install another rod at an angle.
Old 01-12-2012, 01:43 AM   #4
rrolleston's Avatar
Going to call my inspector tomorrow. Not interested in hacking anything up anymore than it already is.
Old 01-12-2012, 03:21 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
The entire rod (or very close to it) needs to be below grade. It doesn't necessarily have to be below ORIGINAL grade, just below FINISHED grade. If you will be adding at least 10" of fill, then you're set.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
TarheelTerp (01-12-2012)
Old 01-12-2012, 07:02 AM   #6
Licensed electrician
Rewards Points: 1,788
Why would you even give someone an idea like this knowing it is not code compliant?
Billy_Bob (01-12-2012)
Old 01-12-2012, 07:19 AM   #7
Julius793's Avatar
Because my outlook in life is if your gona do it do it right, so still when your doing something wrong do it right
Old 01-12-2012, 07:25 AM   #8
Sounds deceptive to me by trying to make something look like something it isn't.
Old 01-12-2012, 07:27 AM   #9
Julius793's Avatar
It is deceptive
Old 01-12-2012, 07:52 AM   #10
Rewards Points: 1,542
Drive another ground rod (or two more if your area needs two). The existing ground rod can be left unconnected for now and you can grind it off and/or bond it to the system at a later date after inspection and it will do no harm.
Do you have enough fill to bring the area (perhaps from the foundation out horizontally past the ground rod two feet and two feet to each side) up to proposed finished grade right now or temporarily for electrical inspection? Is that enough to cover the rod?
Old 01-12-2012, 08:03 AM   #11
rrolleston's Avatar
Yeah think I will do another one at an angle and see how that goes the other rod did the same thing but I was able to remove it and put it at an angle. Even if the inspector passes it knowing it's just bent over will drive me mad. Very fussy about my work.
Old 01-12-2012, 07:09 PM   #12
rrolleston's Avatar
Second attempt was a success. Next step was dis a two foot deep trench and lay the rod in there.
Old 01-12-2012, 07:12 PM   #13
MarginallyQualified
Rewards Points: 2,464
It is deceptive
Meh.
Decptive is cutting to 8' rods in half...
Old 01-12-2012, 07:39 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I just grab em with my left hand, hold a 5lb sledge in my right and threaten them. They usually go the rest of the way in ....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
a_lost_shadow (01-12-2012)
Old 01-12-2012, 07:47 PM   #15
rrolleston's Avatar
The area where I was was like a large dirt covered rock ledge. Was lucky we got the 26" trench dug and got the conduit ran. Where the rods had to be put in it was full of rocks.
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
garage door chain drive to belt drive pberm1962 General DIY Discussions 16 11-26-2011 08:28 PM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 03:13 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
