Umm ... 15 Amp Or 20 Amp? (Might Be A Dumb Question) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 06:08 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Umm ... 15 amp or 20 amp? (Might be a dumb question)
So I'm looking at my breaker panel and trying to figure out "15 amp or 20 amp"
The red ones are labeled:
Bryant
Type BR
BR 120
CU 10-14
AL 8 - 12
The blue ones are labeled:
Bryant
Type BR
BR 115
CU 10-14
AL 8-12
So the only thing is "BR120" vs. "BR115"
So I am thinking red = 20 amp, buel = 15 amp maybe? Any feedback?
What's throwing me for a loop is that almostEVERY outlet in the house was 2-prong but it had the "T-shaped" prong on BOTH sides as if it was a 20 amp.
As far as I can tell, it's OK to have a 15 amp receptacle on both a 15 and 20 amp circuit, but only OK to have a 20 amp receptacle on a 20 amp circuit.
Maybe they used that shape for every outlet back in the 30's ?
CoconutPete is offline   Reply With Quote
Old 04-26-2010, 08:38 PM   #2
Electrician
Rewards Points: 802
I would assume the same thing, the 1 before the number denotes that it is a single pole compared to a 2 pole breaker.
darren is offline   Reply With Quote
Old 04-26-2010, 08:55 PM   #3
fabrk8r
fabrk8r's Avatar
http://forums.mikeholt.com/showthread.php?t=94765
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-26-2010, 09:17 PM   #4
For addt'l confirmation you could pull the cover and check wire sizes; 5/64" dia. for #12, 1/16" dia. for #14.
Old 04-27-2010, 06:35 AM   #5
Rewards Points: 504
Well that helps - thanks, it seems the numbers are right.
I even have 4 empty slots and it seems these breakers are fairly easily accessible.
http://www.pacificcoastbreaker.com/catalog/1543
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 02:50 AM
Dumb HVAC question... 737Pilot HVAC 6 11-03-2008 03:56 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 04:08 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
