UK Flexible Conduit In Home - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 11:18 AM   #1
Lightbulb
UK Flexible conduit in home
Hi all, was wondering if it is OK to use flexible conduit in a household for electrical work, for example to provide a preinstall method for pulling cable in wall.
Thanks.
funtime180 is offline   Reply With Quote
Old 01-09-2011, 11:57 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
It depends on what you jurisdiction allows. Call your local building official and ask the question.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-09-2011, 06:24 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Which area are you from and what type of flexiable conduit or conductor you are talking about ??
There are a bit diffrent rules to deal with it.
Merci,
Marc
Old 01-10-2011, 11:40 AM   #4
Arrow
Further explication
Let me explain in a bit more detail what I am trying to get at.
I lived in Spain for a few years and am now planing on returning to the UK, while I have been living here, I have picked up a few techniques about electrical installation. The way in which cabling is done over here is to mount flexible conduit into the wall then apply the plaster and paint. After then they pull the cable around inside the walls. All this gave me an idea that if the same method was applied in the UK, then I would not have to re-plaster the entire wall to install a cable in a wall at a later date. This would be real useful to finish outstanding projects around the home at a later date without having to re-plaster everywhere just for a run of cable, be it electrical, data, audio, etc.
The kind of conduit I would use would not be dissimilar to what can be found in screwfix.com or the alike. The cable would be anything from 1mm - 2.5mm depending on application, or maybe specialized cable for sound and visual needs.
I hope that this explains my situation further, and look forward to any and all responses.
Old 01-11-2011, 12:13 AM   #5
There are few approved fexiable conduit which you can put in the wall and patch it over the plaster and just pay attetion where you bring in the power from due some case you may snag into the ring circuit or radial circuits they have diffrent way to deal with it.
Oh yeah with most recent UK regulations they will required RCD protection anyway.
As far for the conductor size it will depending on where you hit the circuit and most circuit normally requeid minum of 1.5mm˛ or larger depending on the circuit itself.
Merci.
Marc
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Conduit for #6 wire joey b Electrical 13 11-22-2008 12:13 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 07:43 PM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 02:15 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
