Uhh What's The Blue Wire For? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 10:44 PM   #1
Uhh What's the Blue Wire For?
:o)
New homeowner, changed switches in the basement with no issue, when I got upstairs for the light the wires changed colors on me. I'm not sure which one is which. I'd really like the help. Thank you so much, I tried to take a photo, but it didn't load right.
I have a tan wire, a brown wire, a blue wire. The tan wire is capped by itself,
the brown and blue wire are capped together, the cap has a black sharpie mark on it.
tan positive, brown neg, blue neutral?
thanks for any help, I can try to take another photo if needed.
-mike
MooseGundr is offline   Reply With Quote
The Following User Says Thank You to MooseGundr For This Useful Post:
yorkyork (11-11-2011)
Old 11-09-2011, 11:24 PM   #2
liscenced electrician
Rewards Points: 538
Not enough info to tell anything.
jimmy21 is offline   Reply With Quote
Old 11-10-2011, 07:21 AM   #3
Rewards Points: 3,130
Residential 120 volt electricity is AC (alternating current). There is no positive and negative, only hot (black wire), neutral (white wire), and ground (bare wire). Also occasionally a red wire for multiwire branch circuits or fixtures operated from more than one switch.
What you describe is totally strange. If the wires are "capped" as you describe, what is connected to the switch?
Old 11-10-2011, 07:32 AM   #4
Rewards Points: 320
Usually a black marking means it's the hot wire. So could be the brown and blue together are your hot and the tan is your neutral. Did you try hooking a volt meter up to them to see? You could also get a really long wire and use the continuity test on a multi-meter to check continuity.
Where are these wires you're looking at? Are they in the switch box, or the ceiling? And what kind of wiring do you have to have those colors?
autx790 is offline   Reply With Quote
Old 11-10-2011, 07:59 AM   #5
joed's Avatar
Rewards Points: 12,362
Add your location to your profile. Colours are indicating you are in UK possibly. Was there a fixture there before? How was it connected?
The Following User Says Thank You to joed For This Useful Post:
SD515 (11-10-2011)
Old 11-10-2011, 08:55 AM   #6
i've been trying for 40 minutes to get a picture on this site. Won't take more than 100kb, and it doesn't seem to want to do it when I uploaded to photobucket. This is the link for the photo, I live in the US, and it's for a fixture on the ceiling. The house was built in 69.
http://i46.photobucket.com/albums/f1...r/P1012378.jpg
Old 11-10-2011, 09:06 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
Re-sized using MS Paint
Kyle
Old 11-10-2011, 09:12 AM   #8
Old 11-10-2011, 09:12 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
The tan is (probably) the neutral, the brown and blue are ‘hots’…maybe a feed through or a switch leg. Can you pull the wires out and take another picture so we have a better sense of what is going on in that box? What wires are at the switch box?
Kyle
Old 11-10-2011, 10:21 AM   #10
Rewards Points: 538
The tans are actually discolored whites. They are the neutrals. One of the brown/blue is hot and the other is probably a switch leg. Or they both could be hot. One might be a constant hot for something else
Old 11-10-2011, 11:53 PM   #11
" Euro " electrician
frenchelectrican's Avatar
If the OP live in Chicago area then the colour code is easy to sort it out.
White-Neutral
Grey-Dedicated neutral for GFCI
red-black -blue--Power
Brown--travelers for three way
purple--GFCI protected power
yellow-orange---switch legs
This is a typical set up colour comation that used in Chicago
But I think that brown is switched leg you may want to do little testing to make sure in case the OP is not in Chicago.
Merci,
Marc
Old 11-11-2011, 12:55 AM   #12
blue
in British standard. Only for the cords NOT for the house wires.
Brown is hot.
Blue is neutral.
green with yellow is the ground.
http://www.google.ca/imgres?imgurl=h...9QEwAw&dur=337
yorkyork is offline   Reply With Quote
Old 11-11-2011, 12:29 PM   #13
Brown is hot.
Blue is neutral.
Just let you know the OP is in USA so the UK colour format do not apply in this situation.
Merci,
Marc
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Blue Wire xamplesample Electrical 17 01-18-2009 02:33 AM
