Ufer Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 08:24 PM   #1
I=E/R
a7ecorsair's Avatar
Ufer Ground
My new house has a Ufer ground. What do I need for a clamp to connect my bare ground wire to the 5/8" rebar? Will it actually be listed for rebar or do I use a clamp that is for 1/2" to 1" iron pipe?
a7ecorsair is offline   Reply With Quote
Old 11-01-2010, 08:41 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
You need to use a listed clamp for rebar. Like this one:
http://www.ronshomeandhardware.com/J...014&Click=7805
The Following User Says Thank You to Speedy Petey For This Useful Post:
a7ecorsair (11-01-2010)
Old 11-01-2010, 08:54 PM   #3
I=E/R
a7ecorsair's Avatar
Thanks Speedy
That's the info I need for my shopping trip tomorrow.
Old 11-02-2010, 09:13 PM   #4
I=E/R
a7ecorsair's Avatar
Well, my shopping trip didn't find a ufer clamp and, of course, the store people have know idea what I'm talking about. The two stores I went to had clamps for 1/2" to 1" pipe but there was nothing stating on the package that is was listed for rebar. I can't imagine what would be different about a clamp that will work on 1/2" pipe but not on rebar. Is there actually something cast into the body stating it is L&L for rebar?
Old 11-02-2010, 09:19 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a question:
are you attaching this on an exposed piece of rebar or are you attaching it to a piece of rebar that will be within the concrete?
and if it isn't within the concrete, will it actually be buried?
and a lot of people (including a lot of electricians) do not know what a Ufer ground is (named after Mr. Ufer). It is a concrete encased electrode.
Here's your answer. Everybody carries Blackburn acorn clamps. They say they are rated for rebar and direct burial in earth or concrete. That covers everything, right?:
http://www.ajbsales.com/mar09_IPG_Bl...och_GM8187.pdf
The Following User Says Thank You to nap For This Useful Post:
a7ecorsair (11-03-2010)
Old 11-02-2010, 09:20 PM   #6
Rewards Points: 330
thats the one you want.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
Old 11-03-2010, 06:02 AM   #7
That is the easiest one, to use and find.
For the longest time they were not listed for rebar.
Old 11-03-2010, 07:45 AM   #8
I=E/R
a7ecorsair's Avatar
Thanks NAP for the link and picture. Looks just like the clamp I have except for the stainless steel bolt.....
My electrode is exposed at the top edge of the four foot, poured walls and floor, crawl space.
Question..
I see a lot of mention about ground rods on this forum but I don't recall seeing anything about concrete encased electrodes. Is there a requirement on new construction with concrete footings to include the Ufer electrode?
Old 11-03-2010, 11:57 AM   #9
nap
You talking to me?
nap's Avatar
]a7ecorsair;527850]Thanks NAP for the link and picture.
no problem
Question..
I see a lot of mention about ground rods on this forum but I don't recall seeing anything about concrete encased electrodes. Is there a requirement on new construction with concrete footings to include the Ufer electrode?[
yes. If there is a certain amount of rebar in the concrete foundation (I think it is at least 20 feet of 1/2 or larger bar), you must (per NEC) use that as a grounding electrode.
basically any listed grounding electrode present must be included in the grounding system. If you have a concrete encased electrode, you do not need an additional electrode, including the old standby: rod. It also serves and the additional grounding electrode required when using the water pipe as a grounding electrode.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
