UF Wire Under An Enclosed Deck - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 08:23 AM   #1
UF wire under an enclosed deck
I have a deck which is fully enclosed, in other words the only way under it is through an access door.
I have 12/2 UF wire coming to the deck via a PVC pipe for an outlet but I'd like to add a few more outlets. Is it OK to just staple the additional UF wire to the undersides of the beams or does it need to be fully enclosed in PVC pipe to each outlet box?
mskvarenina is offline   Reply With Quote
Old 07-11-2012, 08:51 AM   #2
Licensed electrician
Rewards Points: 1,864
The UF can be secured to the deck as long as it is not subject to physical damage. If subject to damage it would require protection like conduit.
Old 07-11-2012, 09:09 AM   #3
Rewards Points: 14,290
Any reason it needs to be UF? Much harder to work with because it's so stiff.
Old 07-11-2012, 09:37 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Its in a damp/wet location....
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 01:05 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
