UF Cable Restrictions? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 12:12 PM   #1
Setting up a shop in a farm out-building. Most wiring will be concealed, therefore NM-B is acceptable. However, I have a good bit of UF on hand. Any restrictions on using it in that situation?
edwinb is offline   Reply With Quote
Old 01-08-2013, 12:48 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,990
No restrictions, but it's hard to work with.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-08-2013, 04:11 PM   #3
Right! Thanks.
Old 01-08-2013, 06:04 PM   #4
Rewards Points: 320
You will find the UF cable very difficult to work with especially using it in multiple boxes with devices. It has an inner plastic jacket around the conductors that is hard to cut and strip. You'll save yourself some aggravation if you go out and get some regular NM-B cable.
teamo is offline   Reply With Quote
Old 01-08-2013, 06:12 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There might be restrictions depending on the code cycle your area is under. NEC 2008 restricted the use of NM in outbuildings. Those restriction were eased with the 2011 NEC.
Old 01-08-2013, 11:44 PM   #6
Got it. Thanks!
sound out of cable box amakarevic Home Theater 11 05-18-2012 10:26 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 12:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 08:33 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
