-   -   UF Cable Restrictions? (http://www.diychatroom.com/f18/uf-cable-restrictions-168583/)
edwinb 01-08-2013 01:12 PM
Setting up a shop in a farm out-building. Most wiring will be concealed, therefore NM-B is acceptable. However, I have a good bit of UF on hand. Any restrictions on using it in that situation?
mpoulton 01-08-2013 01:48 PM
No restrictions, but it's hard to work with.
edwinb 01-08-2013 05:11 PM
Right! Thanks.
teamo 01-08-2013 07:04 PM
You will find the UF cable very difficult to work with especially using it in multiple boxes with devices. It has an inner plastic jacket around the conductors that is hard to cut and strip. You'll save yourself some aggravation if you go out and get some regular NM-B cable.
k_buz 01-08-2013 07:12 PM
There might be restrictions depending on the code cycle your area is under. NEC 2008 restricted the use of NM in outbuildings. Those restriction were eased with the 2011 NEC.
edwinb 01-09-2013 12:44 AM
Got it. Thanks!
