UF Cable In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 03:42 PM   #1
Rewards Points: 274
UF cable in conduit
I need to run 360' of 10/2 w/ ground UF cable from house to well. Should I put it in grey pvc conduit (which will probaly be a b****) or should I be ok to just bury the UF cable 2' deep. It will not go under a driveway or anything but will be under pasture where tractor will run over it.
ugabulldog is offline   Reply With Quote
Old 01-04-2011, 03:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
If you are going to run pipe, use thwn instead of the uf cable.
When the lightning hits the well, the wires will be easier to change.
That far from the house, i would consider using a larger wire and putting a small panel at the pumphouse.
This allows you to install a receptacle that that remote location for the what if.
Aren't we both glad that our teams are done for the year.
Heres to better football for the Jackets and the Dawgs!
Old 01-04-2011, 04:16 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
with that long of a run, you should calculate voltage drop to be sure you won't have a problem, especially given this is a motor. If the tractor is only being driven over this, 2' would be fine but if you till the ground, I would go a lot deeper.
Old 01-04-2011, 04:32 PM   #4
Rewards Points: 274
Well drillers calculated voltage drop, thanks
Old 01-04-2011, 08:14 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Just give you a head up not all well drillers will able use the correct voltage caluations drop figures.
With 360 feet of run what size pump motour you have there and what voltage you are on now ??
That will make a diffrence there.
As far for subpanel in the pump house is doable all it depending on where the pressure switch / tank located.
Merci,
Marc
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
MC cable through conduit StudebakerHawk Electrical 3 03-05-2010 10:38 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 02:15 PM
SubPanel-NM Cable in Conduit? blankcek Electrical 9 06-24-2008 10:41 AM
