Uf 6/3 Underground Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 10:32 AM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Ok Patti
I have a chocolate lab named Maggie so I have a great appreciation for kennel owners. In your case though you are remodeling to a cottage.
The reason I asked about the cable is you will need 4 wires in it for your application. You need 2 hots, a neutral, and a ground wire so 4 wires total.
You need to keep the neutrals and grounds separate at the sub-panel in the kennel/cottage building. In other words each will have there own terminal bar at the sub-panel and they will not be electrical connected or bonded. This often means you will need to purchase a ground bar kit for your sub-panel. You will not install the main bonding jumper which is often a green screw that comes in a package with the new sub-panel. Be sure you understand how to keep the ground and neutral isolated electrically from each other. If not ask questions here and we will get you straight on what to do. You will need a couple ground rods.
I'll attach a graphic to illustrate what I am talking about.
Uf 6/3 underground cable-4-wire-subpanel-detached.jpg
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 04-09-2009, 06:45 PM   #17
There is nothing wrong with running UF.
It is almost as easy to run conduit/wire and probably less expensive.
Conduit provides some physical protection as well as an opportunity to replace wires if anything should happen to them.
Stuff happens. Electrical installations do not last forever and underground is one of the most harsh enviroments we encounter.
Use conduit.
220/221 is offline   Reply With Quote
Old 04-09-2009, 07:07 PM   #18
I had only part of my se in conduit, mostly directly buried wire. Now when I had some digging and the se had to be cut and a temp installed, I needed a new SE. Poco wanted conduit, cable wanted conduit, and phone wanted conduit.
Well, poco paralleled two sets of 2/0 AL and 4/0AL for a 400 amp service, this time they used a 250 and two 350s.
rgsgww is offline   Reply With Quote
Old 04-10-2009, 09:41 AM   #19
Hi Stubbie,
Thanks for the info and illustration. I will print this out and pass it on to the electrician.
You know what they say about 2 heads being better then one. I will take all the knowledge I can get seeing I don't have a clue about any of this electric stuff. I'm a para transit driver for a living!
I have learned a lot about remodeling in the last month. The biggest lesson I've learned is once you start tearing things apart, you never know what your going to find!
I have a yellow lab, her name is Jada. She's my 80# lap dog. I also have a Jack Russell/Shiatzu mix. He's the boss of everyone.
Patti K is offline   Reply With Quote
Old 04-10-2009, 09:51 AM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Hi Patti
It's great you have an electrician to help with the project. He probably won't need the diagram so I'd just run the neutral and ground separation past him to see what he says. You must always have 4 wires if you have metal paths (metal water pipe for example) besides the electrical connecting the house with the cottage. It's a good idea no matter whether you do or not. A 4 wire cable is 6/3G or 6/3 with ground. Meaning 3 conductors (2 hots and neutral) plus a ground.
Hope the cottage comes out the way you want.
Stubbie
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
min depth for fiber optic cable underground? MusicMan_234 Electrical 5 01-30-2009 12:32 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Underground cable Lonicera Electrical 6 04-24-2006 06:48 PM
