Type Of Wiring For 60 AMP Forced Air Unit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 09:35 AM   #1
Rewards Points: 342
Question
Type of wiring for 60 AMP forced air unit
What is the gauge and type of wiring used with a 60 AMP forced air unit?
tripower is offline   Reply With Quote
Old 05-02-2010, 10:22 AM   #2
Rewards Points: 168
Look at the nameplate. And what is a "forced air unit"? Is it a fan?
Old 05-02-2010, 10:38 AM   #3
Rewards Points: 342
A forced air unit as opposed to a heat pump. I cannot make out labelling on the existing wiring it looks like TYPE SB 6.
Old 05-02-2010, 02:42 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Do this unit have electric heater in there ??
Really the best and safest way is verify the manufacter nameplate info they will have all the info like voltage , amp plus if have electric heater in there it will tell you what Kw rating in there as well.
once we know the requirement then we can go from there.
Acourding your exsting cable sound like you have 16mm˛ { #6 AWG } if that the case then you have to stay with that size.
Merci,Marc
Old 05-02-2010, 03:03 PM   #5
Electrical Contractor
kbsparky's Avatar
Maybe you have type SE 6? That would be standard for a 60 Amp circuit, capable of powering an air handler, with a 10 kW strip heater installed.
-KB
Old 05-02-2010, 03:39 PM   #6
Rewards Points: 342
Exclamation
I went to the hardware store it is indeed #6 aluminium (multi-strand shielded). But the hardware store only had copper which he says is better. And they also have a single strand ground wire which he says will work as well. Should I move from aluminium to copper and from multi-strand to single strand ground?
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee HVAC 5 06-12-2014 12:00 PM
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Wiring For an A/C Unit schultz56 Electrical 5 02-15-2010 03:03 PM
Getting Gas To A Unit Heater: Type of Pipe? story HVAC 4 10-26-2009 07:19 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
