Type Of Wire To Run To Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 07:49 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Remove the green screw.
Old 12-29-2012, 07:56 PM   #17
Master Electrician
Rewards Points: 3,918
Say What?
brric is offline   Reply With Quote
Old 12-29-2012, 08:12 PM   #18
jbfan's Avatar
Rewards Points: 546
Originally Posted by brric View Post
Say What?
Ok, do it your way then.
Old 12-29-2012, 10:58 PM   #19
Rewards Points: 95
I appreciate all the replies. It's late here so maybe I'm not thinking correctly, but don't ground and neutral wires go to the same bar anyway? What are the separate bars for?
MrAngles is offline   Reply With Quote
Old 12-29-2012, 11:01 PM   #20
Engineer
Rewards Points: 161
They do in the main panel, but not the sub. By connecting the ground/neutral in a sub you will allow current to flow on the grounding conductor.
diystephen is offline   Reply With Quote
Old 12-30-2012, 12:58 AM   #21
Rewards Points: 95
Aha. Do I need to keep all the arc-fault breakers on the side of the box with the neutral bar, or can I run the neutral wires from the breakers around from the other side? Seems like the wiring in the box will be pretty messy.
Old 12-30-2012, 05:14 PM   #22
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you get a bar that will snap into the other side you can use that one as your neutral and the existing one your ground screw in the green screw to make the ground bonded to the metal of the panel.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-30-2012, 05:25 PM   #23
rrolleston's Avatar
You could get it so you have two neutral and ground bars. Have the neutral bars snapped into the plastic interior and two ground bars attached to the panel back. That way you don't have to bring your grounds and neutrals all the way around to the other side.
Old 12-30-2012, 05:48 PM   #24
Rewards Points: 95
Ok so the ground wire DOES have to be connected to the box with the green screw?
Old 12-30-2012, 05:59 PM   #25
Rewards Points: 95
Oh also before I hook everything up I should verify does it matter which of the positive lugs I hook the hot leads to (I don't have to match the left pole on the sub panel to the left pole on the main panel do I?)? Likewise, do I connect the neutral and ground leads right next to each other on the same ground bar in the main breaker?
Old 12-30-2012, 06:02 PM   #26
rrolleston's Avatar
Don't matter what hot lead you connect to what. If you use that bar as a ground bar you have to get a neutral bar that snaps into the other side.
Old 12-30-2012, 06:34 PM   #27
Rewards Points: 95
I meant in the main breaker. I don't have to connect the ground lead in my 6-3 romex to the left neutral/ground bar and connect the neutral to the the right neutral/ground bar in the main breaker do I? I should just be able to connect both wires to the same bar right?
As far as the sub panel goes, I picked up a "ground bar" today that will snap into the left side of the panel. It has screws that can go all the way through it into the frame of the panel to ground it if I want, but I figured I'd just leave it snapped into the plastic not touching any metal and use it as the neutral bar, and use the existing bar as a ground bar if it needs to be screwed into the frame.
Old 12-30-2012, 08:07 PM   #28
Master Electrician
The grounded conductor(white wire) and the grounding conductor(bare copper) of the sub panel feeder cable are connected to the same bar in the main panel.
Old 12-30-2012, 08:57 PM   #29
Rewards Points: 95
That's what I thought, thank you.
Old 12-31-2012, 07:46 AM   #30
Rewards Points: 95
So if I were to do this, what do I use to connect the two ground bars together?
The Following User Says Thank You to MrAngles For This Useful Post:
langless28 (05-15-2013)
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
What type of wire is this? hotot Electrical 5 09-22-2012 05:03 PM
sub panel wire type reengineered Electrical 10 02-17-2012 07:45 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Pool Sub Panel wire / conduit questions Al the Diy guy Electrical 23 02-03-2008 02:32 PM
