Old 10-11-2012, 10:22 AM   #1
Type of wire to run to sub panel
I'm finishing my basement, and decided to add a subpanel for power down there. I'd like to use a 50 or 60 amp breaker in the main panel, but I'm not clear on what wire to use to run to the subpanel. I can't seem to find any romex in 6 gauge or bigger at the big big stores, but I did find this online: http://www.wesbellwireandcable.com/R...mexnmb6-2.html Should I be using romex, or should I be using individual wires in a conduit? Will I need higher than 6 gauge to support 60 amps?
MrAngles is offline   Reply With Quote
Old 10-11-2012, 11:36 AM   #2
J. V.'s Avatar
The wire in the link can be purchased from a local electrical supply house. But, you need 6/3 NM. Not 6/2 NM. You must run four wires to the sub. H-H-N-G.
Old 10-11-2012, 12:23 PM   #3
Thank you, what's the additional wire for?
Old 10-11-2012, 12:56 PM   #4
kbc
the additional wire is for the ground, in a main panel nuetrals and grounds can be together but in a sub panel they hav to be isolated
kbc is offline   Reply With Quote
Old 10-11-2012, 02:29 PM   #5
Isn't 6/2 three wires, hot, neutral and ground? 6/3 is four leads, right?
Old 10-11-2012, 02:33 PM   #6
Correct... 6/3 with ground contains two hots, a neutral, and a ground. One hot would be connected to each pole of your 2-pole feeder breaker in the main panel to run 240V and then connect to the buses in your subpanel (lugs or breaker).
BrandonD is offline   Reply With Quote
The Following User Says Thank You to BrandonD For This Useful Post:
MrAngles (10-11-2012)
Old 10-11-2012, 07:07 PM   #7
Gotcha, cool, thank you.
Old 10-11-2012, 08:02 PM   #8
DIY Enthusiast
sublime2's Avatar
Generally speaking the first # in wire description refers to the gauge (thickness) of the wire.
The second # refers to the amount of wires within the sheathing. The ground is almost never referenced in that # but is almost always there.
sublime2 is offline   Reply With Quote
Old 10-11-2012, 08:06 PM   #9
Licensed Electrician
k_buz's Avatar
You are correct on the gauge, but the second number refers to then number of insulated conductors.
Location...Location...Location
Old 10-11-2012, 08:20 PM   #10
DIY Enthusiast
sublime2's Avatar
Tomato, tomAto.
Terminology.
No?
Old 12-29-2012, 07:22 PM   #11
Okay I have my 50A breaker, my sub panel and my 6-3 NM wire, with three 6-gauge conductors and a ground.
My sub panel has three lugs, two for hot and one for negative? Where do I hook up the ground? Do I just screw it in anywhere on the negative bar? Also since this is just going from the attached garage to the basement (it doesn't go outside anywhere), do I take the green screw out?
(sorry for the poor picture)
Old 12-29-2012, 07:46 PM   #12
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will have to add a ground bar.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-29-2012, 07:47 PM   #13
rrolleston's Avatar
Tomato, tomAto.
Terminology.
No?
Yes it is.
Old 12-29-2012, 08:39 PM   #14
Ok I see where the ground bar will pop in on the left side. Do I need to actually ground it to something in the basement, or is it just a spot for the ground wires to all connect to the 6-3 supply wire's ground?
And how about that green screw?
Old 12-29-2012, 08:49 PM   #15
Master Electrician
Remove the green screw.
brric is offline   Reply With Quote
What type of wire is this? hotot Electrical 5 09-22-2012 06:03 PM
sub panel wire type reengineered Electrical 10 02-17-2012 08:45 PM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
What type wire to use from transfer switch to outdoor outlet brjl Electrical 7 12-02-2009 04:35 PM
Pool Sub Panel wire / conduit questions Al the Diy guy Electrical 23 02-03-2008 03:32 PM
