Old 07-27-2009, 06:59 PM   #1
SNC
Type of wire in coduit.
What is better ? Solid or stranded ? this is 12 ga. in PVC thru the drive way and eventually under the back yard to a shed.
SNC is offline   Reply With Quote
Old 07-27-2009, 07:04 PM   #2
Electrical Contractor
Flip a coin!
Stranded is easier to pull, solid is easier to form. IMHO
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-27-2009, 07:44 PM   #3
Idiot Emeritus
I agree. Solid is slightly less money though. It's also easier to skin up when pushing it into a box.
Rob
micromind is offline   Reply With Quote
Old 07-27-2009, 08:31 PM   #4
SNC
I guess they are equal in capacity.
Old 07-27-2009, 09:40 PM   #5
300zx's Avatar
Post
http://en.wikipedia.org/wiki/Wire Go down to Solid versus stranded
300zx is offline   Reply With Quote
Old 07-28-2009, 12:08 PM   #6
J. V.'s Avatar
Stranded for sure. Not even sure why they make solid THHN.
Old 07-28-2009, 12:27 PM   #7
Xtreme DIY'r
I've always thought that stranded was better on pulls
Old 07-28-2009, 01:21 PM   #8
Send a message via AIM to theatretch85
Solid is easier to push through conduit where as stranded almost always has to be pulled through conduit.
Personally I like stranded when I am connecting to it with wire nuts or directly to outlets that have the pressure plates. Solid is better when connecting directly to a screw only outlet (ie no pressure plates). Obviously its not hard to splice in a piece of solid wire to the stranded wire to connect to an outlet or device where you only have the screw.
Also, it sounds like this is outside so the wire must be wet rated "THWN"
theatretch85 is offline   Reply With Quote
Old 07-28-2009, 09:30 PM   #9
Terminations in standard devices is one reason.
220/221 is offline   Reply With Quote
Old 07-28-2009, 11:03 PM   #10
Union Electrician
goose134's Avatar
I hear you. I prefer stranded for every application I can think of. Still, solid is required for Fire Alarm circuits (at least here in Chicago)
goose134 is offline   Reply With Quote
Old 07-29-2009, 01:35 PM   #11
J. V.'s Avatar
Sorry, but I must disagree with your statement. Solid is MUCH harder to push than stranded unless you have no bends.
220/221
If you have used mostly stranded THHN in your career, like I have, attaching to devices is easy, if you know how. I agree about the loop being easier. I keep some solid around for the pig tails. But it is not needed.
Old 07-29-2009, 07:09 PM   #12
Waht??
Pushing stranded is like pushing rope. 3 solid 12's will push easily thru 20' of 1/2" EMT and a couple 90's. Stranded, not so much.
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
What type of wire to connect motion sensor to light? beezlebub03 Electrical 1 05-31-2008 02:16 PM
Help 220v 4 wire to 3 wire fhome45 Electrical 2 04-22-2008 06:46 AM
damaged wire sheathing rodeo Electrical 11 12-28-2007 10:11 PM
