Type Of Wall Box To Use - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 05:58 PM   #1
Type of wall box to use
I have two rooms divided by a standard wall 2x4 construction with 1/2" sheetrock. How do I go about installing and outlet in the same spot of both walls. If I described that right. I guess back to back. Is there a certain wall box to use or do I need two separate boxes?
thequickness is offline   Reply With Quote
Old 09-01-2008, 06:14 PM   #2
What can I find here?
Winchester's Avatar
Rewards Points: 150
I'm not aware of a "single" box that could be used in your situation. Not enough depth to go back-to-back. I would immagine one would hug the inside of one stud while the other on the opposing inner stud of the same cavity. Hope I'm describing this correctly.
Winchester is offline   Reply With Quote
Old 09-01-2008, 06:41 PM   #3
Registered User
Termite's Avatar
Back to back will be a problem. You'll need to offset them ever so slightly unless you can get away with a pair of shallow boxes (watch your box fill numbers).
Old 09-01-2008, 06:56 PM   #4
Thanks that makes sense. Probably why I didn't that see a box like that on the sites I've been looking at. Thanks
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
