Type Nc Single Pole Breakers To Type Na Single Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 09:48 AM   #1
Type nc single pole breakers to type na single pole
Can I remove one sinlge pole type NA 15 amp breaker and replace it with two NC single pole 15 amp breakers in my old Federal Pacific box?
Wiley is offline   Reply With Quote
Old 12-02-2010, 10:57 AM   #2
Rewards Points: 240
If the panel box allows it. It will tell you on the cover.
Old 12-02-2010, 11:04 AM   #3
According to the panel I can, but looking at the bus bar once the type na breaker is removed, Im not sure that the top Nc breaker will contact correctly.
Old 12-02-2010, 03:30 PM   #4
Electrical Supplier
Rewards Points: 150
The problem here is you have an FPE box. They are inherently dangerous and its more than likely old and worn out. You will probably have issues with it arcing due to poor contact. Keep in mind, most FPE breakers you find are not OEM replacements OR they are refurbed/used.
Do it at your own risk (which is relatively high)
LyonsElecSupply is offline   Reply With Quote
Old 12-02-2010, 05:29 PM   #5
joed's Avatar
Rewards Points: 13,718
Unless the OP is in Canada. We still sell and install new FPE panels.
Old 12-02-2010, 09:44 PM   #6
Electrical Supplier
Rewards Points: 150
I dont know about that man. Were talking about the FPE from the 50's right? Last I knew they have been out of business for the last decade or more. I dont know what new panels you are installing........
Were talking about the Panels of Death right?
Im in the US and we DO NOT sell any "NEW" OEM FPE equipment.
FPE breakers are made by american circuit breaker and are replacements, not OEM. I also dont think they are UL Listed.
Old 12-02-2010, 10:32 PM   #7
joed's Avatar
They are actually called federal pioneer now. Made by Schneider Electric
Old 12-02-2010, 10:33 PM   #8
Electrical Supplier
Rewards Points: 150
Ya I think they are completely different systems. Hes talking about the Old FPE NA and NC breakers.
EDIT, they are the same thing, but just newer (im guessing imcompatable).
But yes, we dont use them in the US anymore to my best knowledge. They are death panels.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Convert single pole switch to a 3 way! Wildie Electrical 19 05-13-2010 10:20 AM
Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers grisha_1 Electrical 4 01-31-2009 07:40 AM
