Tyco Splice Kits - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 01:07 PM   #1
Tyco Splice Kits
I discovered the Tyco Electronics Romex Splice Kit at Home Depot:
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
The description says NEC approved for splicing two wires without a junction box. Does anyone know if this is true? Can I use this splice kit and then cover over it with drywall without an accessible junction box? Will the inspector pass me if I use this? I know general policy is all splices must be done at junction boxes, and all junction boxes must be accessible.
And FYI, I do NOT live in a mobile home. When I tried to google the answer to this question I came up a lot of results that mention this product is commonly used in mobile homes. I don't really know how that changes things, but let's keep this thread focused on what is approved for single family/townhouse/apartments.
jmai14 is offline   Reply With Quote
Old 02-19-2013, 03:25 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The NEC still requires all splices to be accessible.
Maybe I was wrong. But I still say I would not want hidden splices in my walls.
(B) Devices of Insulating Material. Switch, outlet, and
tap devices of insulating material shall be permitted to be
used without boxes in exposed cable wiring and for rewiring
in existing buildings where the cable is concealed and fished.
Openings in such devices shall form a close fit around the
outer covering of the cable, and the device shall fully en-
close the part of the cable from which any part of the cover-
ing has been removed. Where connections to conductors are
by binding-screw terminals, there shall be available as many
terminals as conductors.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-19-2013, 03:41 PM   #3
I don't totally understand your post. Does the NEC allow for these types of splices to be hidden by drywall or not? At first you're saying no, then you seem to indicate yes but you wouldn't.
If this splice must still be accessible, then I don't really see the point of this product. Again, I don't know how accurate the product's claims are, but it's definitely claiming that it can be hidden. From the Home Depot product description: "Splice and Tap Kits also eliminate wire nuts for installation and replace the conventional method for adding a splice or tap for non-metallic cable without the need for exposed and unsightly junction boxes."
Old 02-19-2013, 04:26 PM   #4
rrolleston's Avatar
I would not trust it any mechanical splice can fail and the last thing you want is a hidden splice to fail.
Old 02-19-2013, 04:50 PM   #5
Rewards Points: 1,294
I am not seeing where it says that it can be non-accessable (hidden). It just says that you don't need to use exposed unsightly boxes.
danpik is offline   Reply With Quote
Old 02-19-2013, 05:05 PM   #6
I'm still confused though. What is the point of the product if it must be accessible? The "unsightlyness" is not from the junction box, it's from the fact that you need any kind of accessible panel. If you don't have a junction box, but still have a - I dont know - a door or removable cover or whatever, that's the problem. To me the fact that the product exists implies the wires can be non-accessible because otherwise it's no better visually than a junction box and 8x the price.
Old 02-19-2013, 05:08 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This is your answer....
Tags
electrical , splice kit , splicing
LB fitting and splice bullhome Electrical 2 01-18-2012 04:04 PM
Splice an Underground wire for light post rpearlberg Electrical 23 11-21-2011 05:49 PM
Starter tool kits cellophane Tools 16 10-13-2009 02:58 PM
looking into dye kits/ bleach repair kits 4 carpets. any suggestions? flooring Flooring 3 09-02-2008 09:21 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
