Two Wires Together - Both Sides Black - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 06:23 PM   #1
two wires together - both sides black
I'm installing a new pendant light to replace an existing light in my kitchen. The new lamp has only one wire - with two copper ends. One side is ridged and the other smooth. The directions say to connect the white wire in the lamp to the black wire in the receptacle, etc. How can I determine which is "white" and which is black?
Grammy is offline   Reply With Quote
Old 03-29-2009, 06:29 PM   #2
You talking to me?
nap's Avatar
Rewards Points: 6,290
the ridged wire is the neutral (white) wire
Old 03-29-2009, 06:40 PM   #3
Run an incand. lamp from a known good ground to the short receptacle slot. If this doesn't light the lamp then the receptacle is wired incorrectly.
Don't use a neon tester to do this.
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 09:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
