Two Wire Outlets Ungrounded - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 11:06 PM   #1
Two Wire outlets ungrounded
I have a couple of outlets on different circuits that I would like to add ground to.
I have a crawl space and was looking at dropping a 14 guage ground wire from each outlet into the crawl space and attach it to a terminal block.
And from that terminal block run a ground wire to the grounding rod not back to the panel.
I have not been able to find if that is to code or not or would I have to run each ground wire from each outlet back to the grounding rod.
-L
llevers is offline   Reply With Quote
Old 03-14-2010, 11:38 PM   #2
Learning by Doing
Leah Frances's Avatar
If you have space to run a single ground you have space to do it right and run at new 12/2 or 14/2. No reason to halfass it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-14-2010, 11:51 PM   #3
The circuits do not run in the crawl space, they are all in the interior wall.
That is the issue I don't want to rewire 12 outlets and try to take two circuits back to the main panel just to ground two outlets.
I would rather not tear up drywall though out the whole house trying to trace and re-wire two circuits, just to ground two outlets.
Old 03-15-2010, 12:02 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
NEC 250.130(C)(1) or (2) permits you to do as you have asked. Just be sure your ground rod has a copper grounding conductor connected to it from the service equipment enclosure.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-15-2010, 02:37 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Now,now just tell us how you really feel!
Old 03-15-2010, 12:23 PM   #6
Learning by Doing
Stubbs, what up?! Nice to see ya.
I live in a house that the former owner did everything via shoestring and chewing gum. I am now determined not to take on a project unless I am going to do it right.
Old 03-15-2010, 02:21 PM   #7
Rewards Points: 1,512
Has to go all the way to the panel or to the ground rod or to the fat (typically #6) ground wire connecting the previous two.
Not to another circuit's ground wire (grounding conductor).
So this opens the question about tying the second receptacle's ground wire to the first down in the crawl space.
Not to say I wouldn't go ahead and do it.
It would take more copper but no more complexity continuing the second receptacle's ground from the intended terminal strip location all the way to the grounding electrode system paralleling the first receptacle's ground, as one interpreter of the NEC reported on another forum suggested.
Old 03-15-2010, 02:33 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
I'm still around but have been taking a break for awhile now from the many hours a day on the forum. Been helping my brother- in- law get his electrical contracting business up and going as of late. Lots of people wanting home standby generator back-up power installed to operate during power outages so we have been rather busy.
I agree with you on your suggestion but am just telling the Op that he can do as he wants and remain code compliant since it appears more difficult to run new cables.
Stubbie
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
apartment: 3-pronged, ungrounded outlets pro_DIYer Electrical 9 10-15-2008 04:22 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
