Old 09-13-2009, 07:28 AM   #1
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove
I have a pellet stove that has a blower and a manual thermostat with two wires on 24v. When I set the thermostat to hotter than room tempeture the blower turns on. My question is, I purchased a digital thermostat to upgrade the old one, the new one is a Honeywell RTH221b , but the new thermostat has cool and hot temperature. I'm planning on connecting the hot 24v. wire from the pellet stove to the R letter in the termostat and the return RH letter to the 24v. blower motor. Will this turn my blower on when I set the heat?. And do I need a jumper to give power to the thermostat? and if I do, what letter to what letter do I need the jumper from and to? Thak you for all your help!
Thanks a million
PS. If you read this questuion under Thermostat Wireing on other post is becuase I did not know I have to create my own post. thanks.
jrodtaclet is offline   Reply With Quote
Old 09-13-2009, 07:48 AM   #2
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Can you post the model of your t-stat. R & RH are pretty much the same thing so, no, you wouldn't hook it up like that.
Digital t-stats are set up for several heating systems so, it'll need to be set-up with something close to yours.
Does it have a "C" terminal? Depending on the heating selected, it should hook to W or W1. Since you have heat only, it could also just hook to the fan relay terminal (G)
wirenut1110 is offline   Reply With Quote
Old 09-13-2009, 07:51 AM   #3
I will post some pictures tonight when I get home. Thanks
Old 09-13-2009, 08:21 AM   #4
On second thought, I assumed you had a like a HVAC thermostat. I guess with a stove you would have one with a probe. So my info was based on a t-stat you would use for an HVAC system which is most likely a little different than what you have.
Old 09-15-2009, 06:37 PM   #5
I'll try to hook it up this weekend unless I don't have the right T-stat and have to go buy a different one.
3 wire stove connection bgoldie Electrical 13 03-01-2011 01:29 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 10:11 AM
3 wire connection for new kitchen stove rjniles Electrical 4 09-13-2007 01:59 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 01:20 PM
