Two Way Lever Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 10:20 AM   #1
two way lever switch
I might be calling this switch by the wrong name but I remember seeing them as a kid.
Where would be a good source
First I will tell you what I want to do ?
From my generator I want to run a line to my furnace in case of a power failure.
Just some thing simple and not too costly, as I have never had a long winter power failure problem before. But if I want to switch in a hurry and completely cut off from the electric company's source. This will prevent power back to the working utility person.
The switch has a double leg with a two source to the middle handle, switched to upper legs would be on utilities source and when the switch is down to the lower legs " the generator" source will feed in to the furnace when needed
I wish I could draw a picture but I'm sure you remember these old switches
Robut
robut is offline   Reply With Quote
Old 02-01-2011, 10:22 AM   #2
Rewards Points: 506
DPDT. The old style are exposed and dangerous?
jlmran is offline   Reply With Quote
Old 02-01-2011, 10:25 AM   #3
Rewards Points: 506
Qualifier: That was an answer to your question, but it may not be a good solution for your needs.
Old 02-01-2011, 10:28 AM   #4
Master Electrician
Rewards Points: 3,750
Double-pole double-throw safety switch.
brric is online now   Reply With Quote
Old 02-01-2011, 01:04 PM   #5
Look for a "manual furnace transfer switch" if you want a safe way to do this.
Matsukaze is offline   Reply With Quote
Old 02-01-2011, 08:10 PM   #6
Thanks now I have a lead on what to ask for.
I know wiring but some names of products i don't
thanks Robut
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Home lighting switch installation help needed ... Merk13 Electrical 14 12-29-2010 09:53 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
