-   -   two way lever switch (http://www.diychatroom.com/f18/two-way-lever-switch-94199/)
robut 02-01-2011 09:20 AM
I might be calling this switch by the wrong name but I remember seeing them as a kid.
Where would be a good source
First I will tell you what I want to do ?
From my generator I want to run a line to my furnace in case of a power failure.
Just some thing simple and not too costly, as I have never had a long winter power failure problem before. But if I want to switch in a hurry and completely cut off from the electric company's source. This will prevent power back to the working utility person.
The switch has a double leg with a two source to the middle handle, switched to upper legs would be on utilities source and when the switch is down to the lower legs " the generator" source will feed in to the furnace when needed
I wish I could draw a picture but I'm sure you remember these old switches
Robut
jlmran 02-01-2011 09:22 AM
DPDT. The old style are exposed and dangerous?http://t2.gstatic.com/images?q=tbn:A...QNPvkAH2sFqqr8
jlmran 02-01-2011 09:25 AM
Qualifier: That was an answer to your question, but it may not be a good solution for your needs.
brric 02-01-2011 09:28 AM
Double-pole double-throw safety switch.
Matsukaze 02-01-2011 12:04 PM
Look for a "manual furnace transfer switch" if you want a safe way to do this.
robut 02-01-2011 07:10 PM
Thanks now I have a lead on what to ask for.
I know wiring but some names of products i don't
thanks Robut :thumbup:
