Two Timers On One Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 02:51 PM   #1
two timers on one switch
Hi
I have a dual switch that has the fan and the heat lamp conected to it. I would like to replace that single switch with two timer switches. Right next to it I just have a switch that controls the light in the bathroom.
Is there a switch that has two timers on it?
If not, then I would need one that has a timer and a regular switch to turn the fan+light and then the second timer to turn on the heat lamp.
Thanks,
keano016 is offline   Reply With Quote
Old 04-05-2010, 10:05 PM   #2
Master Electrician
i've never seen a timer switch with a second switch on it let alone a duplex timer switch. They do make timer switches that have a manual throw so that you can bypass the timer though.
andrew79 is offline   Reply With Quote
Old 04-05-2010, 10:40 PM   #3
Lutron makes a dual-control device where one is a timer and one is an incandescent 300W dimmer. It's in the Maestro family of dimmers.
I'm not aware of any devices with two timers in a one-gang device. After selling wiring devices for almost 5 years I can say I've never had anyone ask for that. Odds are it has not come up enough for any major manufacturer to pick this product up. If you do find something come back and let us know.
brich is offline   Reply With Quote
Old 04-06-2010, 09:15 AM   #4
Just call me Andrew
Rewards Points: 1,020
I just bought the combination device brich mentioned, but I have not yet installed it. Here it is (the one on the right):
http://www.lutron.com/cms400/PageBuy...=16957&mn=1799
Andrew
secutanudu is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
