Two Switches, Two Sets Of Lights One Power Source - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 03:59 AM   #1
two switches, two sets of lights one power source
This is the layout that I'm looking to accomplish. Two lights connected to a two gang switch box connected to two more lights. One switch controlling the first set of lights, and the other switch controlling the second set of lights. The power is coming from the light with 12-2. Only the first light is wired so I'll be running all the necessary cable.
agsurfer is offline   Reply With Quote
Old 09-12-2010, 06:00 AM   #2
Rewards Points: 150
Just tap off of the "always on" line power of the first switch, wire it to your new switch and install the new lights. Not really sure if you're asking more than that?
johnnyboy is offline   Reply With Quote
Old 09-12-2010, 09:23 AM   #3
Rewards Points: 1,512
Run an additional 12-2 cable from the light box where the power comes in down to the switch box. (Or use 12-3 cable to connect those items).
The rest of the stuff including the second group of lights is wired up with single 12-2 cables.
The black wire of the additional cable (or the red if a 3 wire cable) is the raw power feed for the switches. The white of the additional cable (or white of a 3 wire cable) is the neutral for the second group of lights.
move 2 switches new location, replace with 2 for new lights qchawkfan Electrical 3 01-24-2010 11:15 AM
bathroom power switches relative to bathtub amakarevic Electrical 7 10-14-2008 03:07 PM
2 lights, 1 source sportstwe Electrical 11 02-14-2008 09:25 AM
power source for recessed lights Jackman Electrical 1 09-18-2006 07:30 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
