Two Switches, Two Lights, One Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 12:10 PM   #1
Rewards Points: 93
two switches, two lights, one box
Does anyone want to take a moment to explain to me how I can wire two switch to two different lights. I have power coming into the switch box and a 14/2 to each light. I want to put two individual switches in a double gang box to control each light. Any help would be awesome!
bfan781 is offline   Reply With Quote
Old 04-12-2010, 12:13 PM   #2
Just call me Andrew
Rewards Points: 1,020
Connect all 3 whites together.
Connect 1 black from each 14/2 (the ones going to the lights) to each switch, it doesn't matter which screw.
You should now have the incoming black remaining. Cut 2 short (8 inches or so) lengths of black wire, put those two into a wirenut with your incoming black. Connect the other ends of the short wires to the other screws on your two switches.
Andrew
secutanudu is offline   Reply With Quote
Old 04-12-2010, 12:14 PM   #3
Master Electrician
on the incomming power make two pigtails(two 6" pieces of wire) and marrette them with the feed. Take one pigtail to one switch and the other pigtail to the other switch. Tie the black from the one light to the unused screw on one switch and the black from the other light to the unused screw on the other switch. Join all your neutrals together(marrette) and install switches with screws to the right.
andrew79 is offline   Reply With Quote
Old 04-12-2010, 01:12 PM   #4
Or if a drawing will help
hayewe farm is offline   Reply With Quote
Old 04-12-2010, 01:33 PM   #5
Rewards Points: 93
Perfect. Thanks for your time. A diagram is worth a thousand words sometimes!!!
Old 04-12-2015, 07:19 PM   #6
Rewards Points: 8
What happens with the ground wires?
Wjosephsimpson is offline   Reply With Quote
Old 04-12-2015, 07:29 PM   #7
Rewards Points: 8
2 lights, 2 switches in one box.
I got how to wire the white and black wires but what I am confused on is the ground wires. Do I need to wire nut the 3 bare ground wires together with 2 short wires to ground to both switches?
Old 04-12-2015, 07:36 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Yes..
The Following User Says Thank You to jbfan For This Useful Post:
Wjosephsimpson (04-12-2015)
Old 04-12-2015, 09:04 PM   #9
Rewards Points: 750
Get yourself a dual pole light switch. It will look like this
Other than that, the other members described it correctly. Wire the 3 whites together. Wire the black POWER wire with 2 pigtails sticking out. Connect 1 to each switch, connect the black wire to the light to the other side. Wire the 3 grounds together, you dont need a wirenut, simply wire all 3 together about 4-6" down & clip 2 off so 1 is sticking out, connect your ground to the ground screw.
Hick is offline   Reply With Quote
Old 04-12-2015, 09:19 PM   #10
Licensed electrician
Rewards Points: 1,486
Many find the duplex switch to be backward to flip the toggles sideways instead of up and down.
Old 04-13-2015, 12:26 AM   #11
Rewards Points: 750
My bad anyways jim. I misread the OP original post. I thought he was attempting to put 2 switches in a single gang box not a double & that was what he was having an issue with. Apologies on that.
Replaced some switches and outlets, now some lights don't work DWooderson Electrical 3 02-02-2010 12:06 PM
move 2 switches new location, replace with 2 for new lights qchawkfan Electrical 3 01-24-2010 11:15 AM
2 switches 2 lights line in through light 1 bldaz Electrical 9 12-24-2009 06:42 PM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 07:34 AM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
