Old 05-26-2011, 04:56 PM   #1
two switches two lights and extra wire
I have one wire gcoming from a light, one coming from the fan, one bringing in the power, and one that goes to the attic. When the wire with power is connected directly to the wire to the attic, I have power to my garage door opener. I now have the wire with power (black) pigtailed to the switches. The black wire from the light to one switch and the the black from fan to other switch. The wire from the attic is directly connected to the blacks, whites, and ground. Now with power turned on the light will switch on and off, the fan staysb on regardless of the switch, and the garage only opend when thye light switch is turned on. Please help!
jevanich is offline   Reply With Quote
Old 05-26-2011, 06:31 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
you have your cables mixed up. The cable that switches the garage is the garage. pigtail it to the always hot. i think you will find that yo have it swapped with the fan cable
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Tags
pigtail, power, switches, wire
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 03:39 PM
Wire a 4-way light circuit with 14/2 HooKooDooKu Electrical 22 01-28-2010 03:31 PM
Extra cable length in the walls? j. pierce Electrical 4 09-12-2009 08:06 AM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 09:46 AM
Want to wire extra lights to garage door opener SuperAkuma Electrical 14 08-02-2008 08:48 AM
