Two Switches In Series For Boiler - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 03:02 PM   #1
WaldenL's Avatar
Rewards Points: 268
Two switches in series for boiler
I'm looking to rewire the power switch for my boiler as I want to move the wires to clean up the overhead in the basement. While I'm at it I'm considering adding a second switch next to the burner wired in series w/the one at the top of the basement stairs. That is, BOTH switches would need to be on for the boiler to run. This way when one is working on the boiler the switch is "right there" and you can see it's off. Anyone see a problem with this idea?
Also going to put a GFI outlet before the switch at the boiler so the worker has ready-access to power. Make sense?
WaldenL is offline   Reply With Quote
Old 01-03-2011, 03:15 PM   #2
joed's Avatar
Rewards Points: 12,852
That would all meet code. I can not think of a reason not to do it.
Old 01-03-2011, 06:31 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,... I'm glad that's all code friendly,...
I've wired my 2 houses that way...
Hope the Gfi part ain't "Needed", as mine are just standard outlets....
I did use the purty Red switch plates for the switches though....
Bondo is online now   Reply With Quote
Old 01-03-2011, 06:54 PM   #4
Rewards Points: 266
Don't tap the boiler circuit for an outlet, that's a code violation.
junkcollector is offline   Reply With Quote
Old 01-03-2011, 08:23 PM   #5
joed's Avatar
If the the room where the receptacle is located is unfinished then GFCI is required.
Old 01-03-2011, 11:11 PM   #6
WaldenL's Avatar
Rewards Points: 268
That's what I was unsure of, even if the outlet is for the boiler service? Code reference by any chance? I'm on NEC 2011... Yes, I know it's only the 4th day of 2011, my AHJ is one of those "current version" AHJs.
Old 01-04-2011, 11:47 AM   #7
Rewards Points: 266
It's been a code requirement for a long time.
422.12 requires central heating equipment to be on an individual branch circuit. Exceptions being pumps, humidifiers, etc that are associated with the equipment.
Old 01-04-2011, 11:50 AM   #8
Just call me Andrew
Rewards Points: 1,020
Aside from the outlet, I just did this as well, both switches in series. The local electrical supplier had the nice red switchplate covers. Both a 4x4 one for downstairs and a standard switch cover for the one upstairs.
Andrew
secutanudu is offline   Reply With Quote
Old 01-04-2011, 11:54 AM   #9
WaldenL's Avatar
Rewards Points: 268
Wasn't doubting the reference, just want to read it for myself. Appreciate it.
Guess I'll run the receptacle off a different circuit. No worries there, I've got several I can chose from. :-)
Old 01-04-2011, 03:01 PM   #10
Code does require a switch near the boiler, I forget how close, but if you do only one, do it near the boiler.
JPraski is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
