Two Quick NEC Code Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 08:59 AM   #1
Question
I tried searching for the answers but came up empty.
Assume 2008 version of NEC (if you know the 2005 was different please note that).
Question 1: (Circuit Breaker Labels)
In a newly built home, is the electrician required to label all breakers in the load center?
Question 2: (Junction Boxes)
Can the inside of a light fixture count as a junction box? For example, the visually appealing hollywood lights in a bathroom have a huge internal space for wiring. Can an electrician skip the junction box in the wall and just run the romex into the light fixture as long as the splices are done inside the light fixture and not the wall?
PS: God bless electricians. I work with state and federal regulations all day and the regulations look like Dr. Seuss compared to the NEC.
Nozler is offline   Reply With Quote
Old 06-14-2009, 09:05 AM   #2
I'm not aware of any code which requires breakers to be labelled
That is usually a contract/purchase issue
A light fixture may be used as a junction box IF it is rated to be used as one
Old 06-14-2009, 09:09 AM   #3
dSilanskas's Avatar
Question 1. Yes the panel must be labled
Question 2. If the light says it can be used as a JB than yes you can.
dSilanskas is offline   Reply With Quote
Old 06-14-2009, 09:11 AM   #4
Do you know the specific code requiring that?
Old 06-14-2009, 09:19 AM   #5
Rewards Points: 2,350
In the 2005 NEC, the Code article is 408.4 for labeling. As far as using the interior of a light for wiring space.... Well, I have done it. I have drilled a hole to accept a connector and popped an MC whip into a strip vanity light. I don't imagine the thing is listed for it, but I personally don't see a problem as long as a connector is used and the light has a back plate.
Old 06-14-2009, 09:24 AM   #6
Thanks!!
I just looked and its the same under 2008
Another thing my electrician did not do when my panel was replaced
I use an Excel Spreadsheet which is then attached to the wall beside the breaker panel. Once the house/addition are complete I'll fill in the panel door
Old 06-14-2009, 09:28 AM   #7
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Just to add, 408.4 in the 08 code added some wording to include labeling "spares" and "no circuit shall be described in a manner that depends on transient conditions of occupancy"
I take this to mean something like "Recept Jim's room" or "new ceiling lights"
wirenut1110 is offline   Reply With Quote
Old 06-14-2009, 10:48 AM   #8
DIY'r
ScottR's Avatar
I like that rule. In the house I bought, the "Guest Bedroom" is now the den, and the "Office" is now the guest bedroom. Until I re-labeled the panel, that was confusing. They also called the "Living Room" the den.
ScottR is offline   Reply With Quote
Old 06-14-2009, 11:07 AM   #9
Yeah, my last house had 3 bedrooms & they were labeled by the kids name
I label by "Front corner room" & indicate 1st or 2nd floor
Back corner room, Middle back room, Kitchen - pretty easy
Main front room, Sunroom, Dining room
That's why I like my spreadsheet, I can be very descriptive
It also includes guage of the wire & breaker size
Since I have an older house (50's) outlets are mixed up in different rooms
I also label new wire or old cloth wire runs
Circuits that are "full" or dedicated runs are in yellow - Do Not Add
It's helped a lot in keeping track of runs/circuits
Old 06-14-2009, 07:24 PM   #10
joed's Avatar
Rewards Points: 13,718
You should see the labels in some of the panels at work. Only people who have worked there for 20 years can interpret them. Joe Smiths office on label indicates a guy who left the company 15 years ago.
Old 06-14-2009, 07:46 PM   #11
A record of what outlet is upstream of what outlet would come in handy but it's best done before the drywall is up.
You can figure it out with a 10A load and DVM but it is tedious.
Old 06-14-2009, 08:02 PM   #12
I had taken pics of all the electrical and plumbing for our house while being built so I would know where everything was. Only problem was my hard drive crashed that the pics were on, all gone. Shame on me for not putting them on another form of backup.
Plumbvoltage is offline   Reply With Quote
Old 06-14-2009, 08:57 PM   #13
No, shame on you for not wiring in a manner that would allow a logical deduction of where the circuits go, even with sheetrock up. I try to combine things similarly. So the dining room and breakfast nook are on the same circuit. The bathroom recepts get a circuit. The lights get their own circuits, etc.
Old 06-14-2009, 09:12 PM   #14
The electrician did a great job wiring it and you can tell where the circuits go.
It was just nice to know exactly which direction the wires went and which way the pipes went for possible future work.
Old 06-15-2009, 12:11 AM   #15
Rewards Points: 508
Send a message via AIM to theatretch85
I believe to be code compliant your spreadsheet label must be on the inside of the panel door or on the face of the panel cover, not on the wall next to it. This may be a jurisdictional thing, as my inspector said that I couldn't have it on the wall next to the panel (even though it was close enough that the paper and the tape was actually touching the panel). I like the spreadsheet idea myself, I only indicate the ampacity of the circuit and the function, all the breakers match the wire size of the entire circuit (at least as far as I know).
theatretch85 is offline   Reply With Quote
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 12:24 PM
Quick cabinet painting questions jimithing78 Painting 2 08-20-2008 12:46 AM
Michigan code questions rondo Electrical 1 12-22-2005 10:37 PM
