Two Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 07:22 PM   #1
two questions
1) Is it required by code to wrap all wire nuts with tape?
2) Is it ok to run 14/3 wire to a lighting fixture that is on a 20amp circuit, for a 3 way switch? The wire goes no further than the second switch (doesn't feed anything beyond it of course), and of course 12/2 is feeding the first switch.
Thanks.
Tonglebeak is offline   Reply With Quote
Old 04-21-2012, 07:29 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Thanks.
1) Absolutely NOT.
2) Absolutely NOT!
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
electures (04-23-2012), micromind (04-21-2012), Ravenworks (04-21-2012)
Old 04-21-2012, 07:46 PM   #3
Rewards Points: 3,256
To expand on Petey's info you will have to upgrade to 12/3 wire or use a 15 amp breaker for the 14/3.
zappa is offline   Reply With Quote
Old 04-21-2012, 09:54 PM   #4
If I may ask, what's the reasoning for that if the wire will feed nothing but a light?
Old 04-21-2012, 09:59 PM   #5
Missouri Bound's Avatar
The NEC requires overcurrent protection which matches the wire:
15 amp breaker with 14 ga wire, and 20 amp breaker with 12 ga wire.
It's not about load protection, it's about wire protection.
Do you want it your way or the right way?
Old 04-21-2012, 10:00 PM   #6
The over current protection (breaker, fuse) also has to protect the wire from getting too hot. 15 amp for 14 gauge, 20 amp for 12 gauge.
Old 04-21-2012, 10:04 PM   #7
Well, that's what I get for not asking questions before I do the work.
Thanks.
Old 04-21-2012, 10:06 PM   #8
Come here FIRST next time!
:b angin:
Old 04-21-2012, 10:08 PM   #9
Yeah, my wallet is owning my face right now.
Old 04-21-2012, 10:13 PM   #10
Dumb question. What if a 15amp gfi receptacle is before the switch?
Old 04-21-2012, 10:16 PM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can do that, but you would still have to replace the wire as well.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (04-21-2012)
Old 04-21-2012, 10:20 PM   #12
A GFI is NOT a circuit breaker and has nothing to do with overcurrent protection.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Jim Port (04-22-2012)
Old 04-21-2012, 10:29 PM   #13
Alright, thanks guys. I think I'll just run 14/2 (or 3, if it's allowed to be tied into the breaker box with the red conductor not used of course, since that's all I have for the moment is 14/3) and just tie that into all of my 14/3 switches I currently use. and reroute the 12/2 somewhere else :\
When it comes to a dual switch box, what's the procedure for feeding 2 switches off of one wire? Wire nut jumpers from the feeder to each switch?
Old 04-22-2012, 03:12 AM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
So...you think your the first one to ever make that mistake? Get in line....
Another option....if your certain that you don't really need 20a...replace the 20a breaker with a 15a breaker....
Old 04-22-2012, 06:43 AM   #15
Rewards Points: 1,548
When it comes to a dual switch box, what's the procedure for feeding 2 switches off of one wire? Wire nut jumpers (pigtails) from the feeder to each switch?
Yes.
Also use a pigtail when two wires want to go under one screw; wrap the pigtail end around the screw and its other end to the two other wires in question.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
