Two Prong Outlets In Home Just Purchased - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2012, 07:10 PM   #1
two prong outlets in home just purchased
is there a reason to change to three prong outlets
dan scheffel is offline   Reply With Quote
Old 11-14-2012, 07:40 PM   #2
Rewards Points: 13,712
The only legal way to do it is by changing them to a GFI outlet.
Still not going to have a ground but then you could plug in a three prong plug.
When you cange them you have to put the sticker that comes with it that says ungrounded.
Old 11-14-2012, 08:25 PM   #3
Reason? No.
Only problem arises when you have a 3 prong plug to plug in.
Those little cheaters that convert 3 prong plug to a 2 prong plug are not the answer.
parman is offline   Reply With Quote
Old 11-14-2012, 08:54 PM   #4
Rewards Points: 6,652
Only if you are wanting to use Surge protection for your expensive electronics, and wanting proper GFCI circuits in bath, Kitchen, basement, outside, garage, crawl space, etc..
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Changing two prong electrical outlets to grounded three prongs Jabar714 Electrical 4 12-21-2010 01:14 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Replace 2 prong outlets with 3 prong outlets rpsjn4 Electrical 27 01-17-2010 01:34 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
