Old 12-03-2012, 12:03 PM   #1
two outlets with switch at end - troubleshoot help
Hello all,
I recently had two outlets installed on a new breaker, working fine. i have a smarthome remote control switch keypad which, needing a power feed, was connected to the end of the line. now the outlets don't work, but the switch does. it's on a 15A breaker. Any ideas? HELP!
jitani is offline   Reply With Quote
Old 12-03-2012, 12:04 PM   #2
Electrical Contractor
How did you wire it?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-03-2012, 01:45 PM   #3
joed's Avatar
You wired it wrong. Since I can't see what you did through the internet, if you tell us how you wired it maybe we can then tell you where you went wrong.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-03-2012, 04:38 PM   #4
The neutral wire out of the outlet was connected into a cluster, so the neutral wire from the switch was clumped into that, and the power line from the terminal outlet was fed out from the back of the outlet and connected to the switch. can you tell me how it is supposed to be wired if this is wrong? because BOTH outlets on the circuit now do not work, not just the last one.
Old 12-03-2012, 08:39 PM   #5
joed's Avatar
What is the switch going to control. As it is it sounds like you connected the switch as a direct short on the circuit.
Tags
electrical, outlet, switch
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Wiring a bedroom with a switch and outlets clarkjoh Electrical 1 06-06-2012 11:53 AM
switch controls one set of outlets as well as another single outlet metaphys Electrical 14 04-04-2012 12:56 PM
Please help me troubleshoot my 3 way switch campbesh General Discussion 3 02-19-2010 03:17 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
